[mapserver-dev] PHP Mapscript - Query a Standalone File Geodatabase Table using queryByAttributes
Joseph Jeurissen
jjeurissen at houstoneng.com
Mon Oct 8 08:26:45 PDT 2012
Hello,
Has anyone ever queried a standalone file geodatabase table that doesn't have any geometry associated with it? I am able to query feature classes that have points just fine. You shouldn't have to define an extent or have geometry if you are just querying the attributes, right? Every time the script is ran it just returns a 500 status error. The Apache log only shows: "Premature end of script headers: mapserv.exe". I am using Mapserver 6.0.3 and PHP 5.3.10.
Here is the relevant PHP code:
$map = ms_newMapObj($path);
$layer = $map->getLayerByName($info[1]);
$layer->set('status', MS_DEFAULT);
$layer->set('template', $layer->getMetaData('identify_record'));
$layer->queryByAttributes("COUNTY_NO",$COUNTY_NO, MS_SINGLE);
$results = $map->processquerytemplate(array(), false);
And here is the mapfile that I am using:
MAP
NAME 'SSTS_Abandonment'
STATUS ON
LAYER
NAME SSTS_Abandonment
CONNECTIONTYPE OGR
CONNECTION 'E:\websites\maps\data\Zoning\Zoning.gdb'
DATA 'SSTS_Abandonment'
STATUS ON
TYPE QUERY
METADATA
'identify_record' 'SSTS_Abandonment_identify.html'
END
END #LAYER
END #MAP FILE
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20121008/7c3c52e8/attachment-0001.html>
