[mapserver-dev] WFS Filter encoding issue
Yves Jacolin yves.jacolin at camptocamp.com
Tue Sep 11 02:53:46 PDT 2012
@Bart,
It is working at least for GeoServer and I don't think it won't work for
ArcGIS, you are right.
@dev,
Does anyone knows if it Is a MS issue?
Y.
2012/9/11 Bart van den Eijnden <bartvde at osgis.nl>
> Yves,
> what does your FILTER parameter look like in the MAP file? What if you
> include the <Filter> tags in there? I think MapServer would skip adding
> them with <ogc:Filter>.
> Which would make GeoServer happy, but not sure about ArcGIS.
> Otherwise I would change the following line in MapServer code to use
> xmlns:ogc:
> https://github.com/mapserver/mapserver/blob/master/mapwfslayer.c#L152
> Best regards,
> Bart
> OSGIS - http://osgis.nl
> On Sep 11, 2012, at 10:43 AM, Yves Jacolin <yves.jacolin at camptocamp.com>
> wrote:
> ticket on github is: https://github.com/mapserver/mapserver/issues/3414
> Y.
> 2012/9/11 Yves Jacolin <yves.jacolin at camptocamp.com>
>> Le 11/09/2012 10:31, Bart van den Eijnden a écrit :
>>  Hey Yves,
>>> I think it makes sense to file a ticket for this.
>>> Best regards,
>>> Bart
>>>  Ok looking more carefully in the bugtracker I find this ticket
>> http://trac.osgeo.org/**mapserver/ticket/3414<http://trac.osgeo.org/mapserver/ticket/3414>
>> which looks similar. We have the same issue with arcgis WFS service.
>> To give more details: we are doing some testing on MapServer and
>> GeoServer WFS services and our customer is testing ArcGIS WFS service.
>> Both GeoServer and ArcGIS services give same results (error using ogc
>> namespace without xmlns:ogc).
>> Y.
>> Responsable Formation et Support
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel (France) : +33 4 79 26 57 98
>> Mob. : +33 6 18 75 42 21
>> Fax : 04 79 70 15 81
>> Mail : yves.jacolin at camptocamp.com
>> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120911/6e70f2cd/attachment.html>
