[mapserver-dev] WFS Filter encoding issue
thomas bonfort
thomas.bonfort at gmail.com
Thu Sep 13 00:31:11 PDT 2012
Andreas
On Wed, Sep 12, 2012 at 11:28 AM, Eichner, Andreas - SID-NLKM
<Andreas.Eichner at sid.sachsen.de> wrote:
> Hi,
> you might try appending a NAMESPACE parameter: http://jira.codehaus.org/browse/GEOT-1740 This is intended to support the TYPENAME parameter when using namespace qualified type names but depending on the implementation it might help for the FILTER too.
>> Does anyone knows if it Is a MS issue?
> Basically yes. Using namespace qualified XML requires namespace declaration.
does https://github.com/mapserver/mapserver/issues/3414 need
re-opening or should this be tracked in a new issue? what kind of
workload is needed to fix this?
thanks,
thomas
> hth
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
