[mapserver-dev] WFS Filter encoding issue
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Sep 13 00:25:16 PDT 2012
Le 12/09/2012 11:28, Eichner, Andreas - SID-NLKM a écrit :
> Hi,
> you might try appending a NAMESPACE parameter: http://jira.codehaus.org/browse/GEOT-1740 This is intended to support the TYPENAME parameter when using namespace qualified type names but depending on the implementation it might help for the FILTER too.
>> Does anyone knows if it Is a MS issue?
> Basically yes. Using namespace qualified XML requires namespace declaration.
> hth
Hello,
Bart's message helped me a lot. Your tips help me also anyway. Thanks,
Y.
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
