[mapserver-dev] Request for review/comments on RFC 85 (Contour Layer Rendering)
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Sep 20 10:58:23 PDT 2012
I guess this thread begs the questions:
If you use the CONNECTIONTYPE CONTOUR,
Can I ALSO use TILEINDEX instead of DATA?
Can I ALSO use DATA that references a TILEINDEX layer name?
These should be noted in the RFC.
-Steve
On 9/20/2012 1:38 PM, Brent Fraser wrote:
> Mike,
> That was my thinking; I was trying to see if we could avoid using
> CONNECTIONTYPE to solve a problem we ran into with TILEINDEX. (when we
> only had the DATA 'shapefile' method of specifying the source).
> And it got me thinking of the other kinds of hybrid processing might
> do in the future:
> DEM -> vector lines (contouring)
> DEM -> image (hillshade, etc)
> image -> DEM (photogrammetry, not likely!)
> raster -> vector point symbols( vector field rendering, )
> Or maybe it is better left to WPS...
> Best Regards,
> Brent Fraser
> On 9/20/2012 11:20 AM, Smith, Michael ERDC-CRREL-NH wrote:
>> Brent,
>> I wonder if you could use postgis rasters (or oracle rasters) with this
>> the same way tileindexes are done. With 2 layers. See
>> https://github.com/mapserver/mapserver/wiki/MapServer-TILEINDEXes-with-Data
>> base-RASTERS
>> Mike
>> On 9/20/12 12:36 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
>>> Hmm, I see we've already started down the CONNECTIONTYPE road with RFC
>>> 78 (CONNECTIONTYPE UVRASTER)...
>>> Best Regards,
>>> Brent Fraser
>>> On 9/20/2012 10:26 AM, Brent Fraser wrote:
>>>> Alan,
>>>> Looks very interesting, especially the concept of a "hybrid" layer
>>>> (raster in, lines out). Using CONNECTIONTYPE to specify the
>>>> contouring of the raster seems like overloading the meaning of that
>>>> object somewhat, but I don't really have a better solution. One of the
>>>> problems of using CONNECTIONTYPE is that I won't be able to get my
>>>> raster from PostGIS (unless i go through OGR?).
>>>> We have a few of other hybrid (+/-) layers:
>>>> tile index
>>>> GRID
>>>> Chart
>>>> each specified in their own way. I think I would prefer the TILEINDEX
>>>> way of referencing another layer to get the details of the input:
>>>> LAYER
>>>> NAME "dem"
>>>> TYPE raster
>>>> CONNECTIONTYPE "postgis"
>>>> DATA "myRasterTable"
>>>> END
>>>> LAYER
>>>> TYPE line
>>>> DATA "dem" # the name of the input layer
>>>> PROCESSING "Contour"
>>>> or it just may be more confusing and not worth the flexibility...
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 9/20/2012 9:40 AM, Alan Boudreault wrote:
>>>>> Hi devs,
>>>>> I'd like to request some review on a pending RFC regarding support
>>>>> for contour layer rendering.
>>>>> Please see
>>>>> https://raw.github.com/mapserver/docs/master/en/development/rfc/ms-rfc-8
>>>>> 5.txt
>>>>> The official rfc page should be updated in about a hour.
>>>>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html.
>>>>> Thanks,
>>>>> Alan
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
