[mapserver-dev] [WFS] define the geometry column in WFS as datasource
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Sep 20 12:14:37 PDT 2012
I agree with Thomas, those two issues are not related each other.
I will do more test tomorrow for the namespace part with MapServer and next
week with ArcGIS if possible.
Y.
2012/9/20 thomas bonfort <thomas.bonfort at gmail.com>
> I'm going to have to disagree a bit with Steve here: please open two
> distinct pull requests as those seem to be very unrelated issues, so
> we can decide to incorporate one or the other independently.
> thanks,
> thomas
> On Thu, Sep 20, 2012 at 6:13 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us> wrote:
> > I think I'd recommend creating a single ticket that refers to your pull
> request. The ticket will should provide the necessary context to understand
> what you've done. I think once we get a look at the changes we can make a
> decision on if and when to include the changes. The metadata addition
> doesn't seem disruptive since by default things should work as they do now.
> The other seems, potentially, more disruptive.
> > We welcome contributions from all users, hardcore devs or not so *thank
> you*!
> > Steve
> > -----Original Message-----
> > From: mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Yves Jacolin
> > Sent: Thursday, September 20, 2012 10:43 AM
> > To: mapserver-dev List
> > Subject: [mapserver-dev] [WFS] define the geometry column in WFS as
> datasource
> > Hello,
> > This week I find a limitation in MapServer configuration when using a
> WFS servcie as a datasource (aka MS as a WFS client).
> > As you can see here [1] the geometry column is hardcoded in code but
> some WFS services are not using Geometry as a column name (ArcGIS WFS
> sercices are using Shape instead, GeoServer is depending configuration of
> the layer).
> > I prepared a PR this week and tested it with a GeoServer instance. this
> PR add a new metadata for WFS client nammed geometryName (it could be a
> better name of course) to setup the name of the geometry column in the
> filter send by MS.
> > I have also some modifications related to namespace issue which should
> be added in tags, two examples:
> > <ogc:Filter xmlns:ogc='http://www.opengis.net/ogc'>
> > <gml:Box xmlns:gml="http://www.opengis.net/gml">
> > I would like to know what is the best process: do I need to create two
> tickets and propose my PR in some way?
> > Does MapServer developers are interesting about this two modifications?
> > Does this contribution could be added in the next release of MS (aka
> 6.2), is it too late? Are you interesting to get a PR in 6.0.x branche?
> > The last information is that I am **not** a developper at all but it was
> not so hard to do it finally :)
> > Thanks,
> > Y.
> > [1]
> https://github.com/mapserver/mapserver/blob/master/mapwfslayer.c#L242
> > Responsable Formation et Support
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel (France) : +33 4 79 26 57 98
> > Mob. : +33 6 18 75 42 21
> > Fax : 04 79 70 15 81
> > Mail : yves.jacolin at camptocamp.com
> > http://www.camptocamp.com
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
<yves.jacolin at camptocamp.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20120920/5793e662/attachment.html>
