[mapserver-dev] Label positioning around points
Havard Tveite
havard.tveite at umb.no
Fri Sep 21 02:55:45 PDT 2012
On 7/18/2012 5:45 PM, Christy Nieman wrote:
> Hi all,
> I was just wondering if the position order around points is still open for comment.
> I know that there was discussion about this in the spring, and that a change was implemented (though, I have to admit that I just noticed the difference when comparing a tile cache that I created before the change to one created a couple weeks ago). I'm not sure if having UC and LC as the first two positions considered preferable to how the positioning worked before. In a cluttered map, I find it non-intuitive to associate a point with a label that is centred above/below it. I would personally expect something like UR, UL, LR, LL, CR, CL, UC, LC. Map labelling convention for points based on what I remember from my schooling and my experiences since then seem to prefer UR and LR as the first locations to consider.
> If it is not desirable to implement another change to the AUTO label position order, perhaps it is necessary to consider the suggestion from the spring to have the option of specifying a custom "AUTO" label placement order (no idea how difficult this would be to implement).
> I just wanted to throw this out there.
> Regards,
> Christy
I suggest that we do something about this, and I hope that it
can be done before 6.2 is released.
I have found out that the AUTO label positioning is done in
mapdraw.c.
For points the AUTO behaviour has changed from 6.0 to master.
If the behaviour is to be changed, it should be done in
accordance with cartographical literature and best practice.
In "Thematic Cartography and Geographic Visualization", 2nd
edition (Slocum, et. al., 2005), the following sequence is
listed for point labeling (referring to Pinhas Yoeli, 1972,
but modified to give preference to R placement - same as
for legends):
UR,LR,UL,LL,UC,LC,CR,CL.
CR and CL are placed last, because those positions can result
in "unfavourable optical coincidence" (Imhof 1975) - the point
symbol could be misinterpreted as a type character in the label.
In "Elements of Cartography" (Robinson, et.al.), the following
sequence is listed for point labelling:
UR,UL,LR,LL,UC,LC (CR and CL are not included, but some more
variants of upper placement are listed as 7-9).
The way I see it, it would be useful to change the behaviour
of Mapserver auto labelling.
1) UR must be given the highest priority.
2) LL, UC, LC, CR and CL should be given lowest priority.
3) Someone must decide the sequence for LR and UL.
These are then the two possible sequences:
UR,UL,LR,LL,UC,LC,CR,CL
I see two options for 6.2:
a) modify mapdraw.c to revert to 6.0 behaviour.
b) modify mapdraw.c by changing the sequence to one that
is according to cartographical practice and literature.
Håvard
Mapserver label placement auto:
6.0 (and 5.6):
Polygon:
positions[0]=MS_CC;
positions[1]=MS_UC;
positions[2]=MS_LC;
positions[3]=MS_CL;
positions[4]=MS_CR;
Line:
positions[0]=MS_UC;
positions[1]=MS_LC;
positions[2]=MS_CC;
Point:
positions[0]=MS_UL;
positions[1]=MS_LR;
positions[2]=MS_UR;
positions[3]=MS_LL;
positions[4]=MS_CR;
positions[5]=MS_CL;
positions[6]=MS_UC;
positions[7]=MS_LC;
master:
Polygon:
positions[0]=MS_CC;
positions[1]=MS_UC;
positions[2]=MS_LC;
positions[3]=MS_CL;
positions[4]=MS_CR;
Line:
positions[0]=MS_UC;
positions[1]=MS_LC;
positions[2]=MS_CC;
Point:
positions[0]=MS_UC;
positions[1]=MS_LC;
positions[2]=MS_CR;
positions[3]=MS_CL;
positions[4]=MS_UR;
positions[5]=MS_UL;
positions[6]=MS_LR;
positions[7]=MS_LL;
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
