[mapserver-dev] OGR/MySQL Layer executes SQL query twice
Brent Fraser
bfraser at geoanalytic.com
Wed Apr 10 15:08:40 PDT 2013
Any,
Back in late 2009 (search the email list in Dec 2009 and Mar 2010)
there was an effort to implement RFC 52: One-pass query processing
(http://mapserver.org/development/rfc/ms-rfc-52.html), but I'm not sure
if it was implemented. (Status=draft?).
Dunno if it relates to your problem...
Best Regards,
Brent Fraser
On 4/10/2013 2:23 PM, deuce2367 wrote:
> Steve,
> That's a good suggestion. I'm running a very simple test where I use
> shp2img with a straightforward map file but if I used ogr2ogr that
> would take Mapserver out of the equation altogether. I'll try and set
> up such a test and see what happens.
> Cheers,
> -Andy
> On Wed, Apr 10, 2013 at 2:06 PM, Lime, Steve D (MNIT) [via OSGeo.org]
> <[hidden email] </user/SendEmail.jtp?type=node&node=5045913&i=0>> wrote:
> Is there a way to test your theory independent of MapServer using
> OGR only? I don't know the MapServer OGR driver well but I can't
> imagine this is normal.
> Steve
> -----Original Message-----
> From: [hidden email]
> <http://user/SendEmail.jtp?type=node&node=5045879&i=0>
> [mailto:[hidden email]
> <http://user/SendEmail.jtp?type=node&node=5045879&i=1>] On Behalf
> Of deuce2367
> Sent: Tuesday, April 09, 2013 9:20 AM
> To: [hidden email]
> <http://user/SendEmail.jtp?type=node&node=5045879&i=2>
> Subject: [mapserver-dev] OGR/MySQL Layer executes SQL query twice
> I'm using Mapserver 6.0.2 and GDAL 1.7.2 and have created a
> mapfile with an OGR/MySQL layer. The SQL query that retrieves the
> spatial data is fairly slow, takes about 8-10 seconds. I've
> noticed that whenever I render the layer (via the mapserv binary
> or via the shp2img utility) that the query executes two times. I
> thought this was maybe some sort of introspection/reflection issue
> where perhaps OGR is trying to characterize the data somehow so I
> made sure to create and populate the geometry_columns table but
> that doesn't seem to help, it's still running the SQL query twice.
> Incidentally it's also performing 2 describes and 2 'select from
> geometry_columns...' as well.
> Is this normal and expected?
> I apologize if this is a repeat, I didn't find any references to
> this observation in my searches. Appreciate any help,
> -Andy Smith
> http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536.html
> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
> mapserver-dev mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5045879&i=3>
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5045879&i=4>
> If you reply to this email, your message will be added to the
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536p5045879.html
> To unsubscribe from OGR/MySQL Layer executes SQL query twice,
> click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: OGR/MySQL Layer executes SQL query
> twice
> <http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536p5045913.html>
> <http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html> at
> Nabble.com.
> mapserver-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130410/2d6f2314/attachment.html>
