[mapserver-dev] OGR/MySQL Layer executes SQL query twice
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Apr 10 17:48:22 PDT 2013
Don't think so... This for drawing. Still could be an issue, but I hope not.
_______________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of Brent Fraser [bfraser at geoanalytic.com]
Sent: Wednesday, April 10, 2013 5:08 PM
To: deuce2367
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] OGR/MySQL Layer executes SQL query twice
Any,
Back in late 2009 (search the email list in Dec 2009 and Mar 2010) there was an effort to implement RFC 52: One-pass query processing (http://mapserver.org/development/rfc/ms-rfc-52.html), but I'm not sure if it was implemented. (Status=draft?).
Dunno if it relates to your problem...
Best Regards,
Brent Fraser
On 4/10/2013 2:23 PM, deuce2367 wrote:
Steve,
That's a good suggestion. I'm running a very simple test where I use shp2img with a straightforward map file but if I used ogr2ogr that would take Mapserver out of the equation altogether. I'll try and set up such a test and see what happens.
Cheers,
-Andy
On Wed, Apr 10, 2013 at 2:06 PM, Lime, Steve D (MNIT) [via OSGeo.org] <[hidden email]</user/SendEmail.jtp?type=node&node=5045913&i=0>> wrote:
Is there a way to test your theory independent of MapServer using OGR only? I don't know the MapServer OGR driver well but I can't imagine this is normal.
Steve
-----Original Message-----
From: [hidden email]<http://user/SendEmail.jtp?type=node&node=5045879&i=0> [mailto:[hidden email]<http://user/SendEmail.jtp?type=node&node=5045879&i=1>] On Behalf Of deuce2367
Sent: Tuesday, April 09, 2013 9:20 AM
To: [hidden email]<http://user/SendEmail.jtp?type=node&node=5045879&i=2>
Subject: [mapserver-dev] OGR/MySQL Layer executes SQL query twice
I'm using Mapserver 6.0.2 and GDAL 1.7.2 and have created a mapfile with an OGR/MySQL layer. The SQL query that retrieves the spatial data is fairly slow, takes about 8-10 seconds. I've noticed that whenever I render the layer (via the mapserv binary or via the shp2img utility) that the query executes two times. I thought this was maybe some sort of introspection/reflection issue where perhaps OGR is trying to characterize the data somehow so I made sure to create and populate the geometry_columns table but that doesn't seem to help, it's still running the SQL query twice.
Incidentally it's also performing 2 describes and 2 'select from geometry_columns...' as well.
Is this normal and expected?
I apologize if this is a repeat, I didn't find any references to this observation in my searches. Appreciate any help,
-Andy Smith
View this message in context: http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
mapserver-dev mailing list
[hidden email]<http://user/SendEmail.jtp?type=node&node=5045879&i=3>
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
[hidden email]<http://user/SendEmail.jtp?type=node&node=5045879&i=4>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536p5045879.html
To unsubscribe from OGR/MySQL Layer executes SQL query twice, click here.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: OGR/MySQL Layer executes SQL query twice<http://osgeo-org.1560.x6.nabble.com/OGR-MySQL-Layer-executes-SQL-query-twice-tp5045536p5045913.html>
Sent from the Mapserver - Dev mailing list archive<http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html> at Nabble.com.
mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
