[mapserver-dev] Mapserver thread safety
Umberto Nicoletti umberto.nicoletti at gmail.com
Wed Aug 14 00:46:05 PDT 2013
On Wed, Aug 14, 2013 at 9:39 AM, Andreas Albarello <
andreas.albarello at tol.bz.it> wrote:
> Umberto,
> thank you. I think this should be ok, and I agree with Thomas' comment to
> the original pull request that OCI_THREADED should require USE_THREADS to
> be defined.
I have added that after I sent the first email, so I suppose it's good for
merging.
Umberto
> Unfortunately, I lost my MapServer build environment in a HDD crash two
> weeks ago and haven't yet had time to put everything together again, so I
> can't help with testing this right now. I will say though that I have been
> compiling MapServer with OCI_THREAEDED in maporaclespatial.c for some time
> now and haven't noticed any adverse effects. As I said, I did find though
> that some weird crashes in conjunction with an 11g client (10g clients did
> seem to be a lot more stable in this regard) went away which I think is a
> good thing and what prompted my response in the first place.
> Regards,
> Andreas
> On 14.08.2013 09:07,umberto.nicoletti at gmail.com wrote:
> > I have added OCI_THREADED to the flags passed to OciEnvCreate as per
> > Andreas suggestion (and fixed a few compile warnings while at it).
> > You can checkout the changes:
> > https://github.com/mapserver/mapserver/pull/4729
> > I'd like to merge this into master today, so I'd really appreciate it if
> > someone could test it right away. I'll be on #mapserver if you need
> > assistance.
> Andreas Albarello
> Analysis & SW Development
> Territorium Online srl/GmbH
> Via Buozzi Str. 12
> I 39100 Bolzano/Bozen
> Phone:  +39 0471 068611
> Fax:    +39 0471 068619
> email: andreas.albarello at tol.bz.it
> web:   http://www.tol.bz.it
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130814/e68983bb/attachment.html>
