[mapserver-dev] Mapserver thread safety
Umberto Nicoletti
umberto.nicoletti at gmail.com
Wed Aug 14 00:53:12 PDT 2013
merged, thanks to everyone
On Wed, Aug 14, 2013 at 9:49 AM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
> +1 for merging
> On 14 August 2013 09:46, Umberto Nicoletti <umberto.nicoletti at gmail.com>
> wrote:
> > On Wed, Aug 14, 2013 at 9:39 AM, Andreas Albarello
> > <andreas.albarello at tol.bz.it> wrote:
> >> Umberto,
> >> thank you. I think this should be ok, and I agree with Thomas' comment
> to
> >> the original pull request that OCI_THREADED should require USE_THREADS
> to be
> >> defined.
> > I have added that after I sent the first email, so I suppose it's good
> for
> > merging.
> > Umberto
> >> Unfortunately, I lost my MapServer build environment in a HDD crash two
> >> weeks ago and haven't yet had time to put everything together again, so
> I
> >> can't help with testing this right now. I will say though that I have
> been
> >> compiling MapServer with OCI_THREAEDED in maporaclespatial.c for some
> time
> >> now and haven't noticed any adverse effects. As I said, I did find
> though
> >> that some weird crashes in conjunction with an 11g client (10g clients
> did
> >> seem to be a lot more stable in this regard) went away which I think is
> a
> >> good thing and what prompted my response in the first place.
> >> Regards,
> >> Andreas
> >> On 14.08.2013 09:07,umberto.nicoletti at gmail.com wrote:
> >> > I have added OCI_THREADED to the flags passed to OciEnvCreate as per
> >> > Andreas suggestion (and fixed a few compile warnings while at it).
> >> > You can checkout the changes:
> >> > https://github.com/mapserver/mapserver/pull/4729
> >> > I'd like to merge this into master today, so I'd really appreciate it
> if
> >> > someone could test it right away. I'll be on #mapserver if you need
> >> > assistance.
> >> Andreas Albarello
> >> Analysis & SW Development
> >> Territorium Online srl/GmbH
> >> Via Buozzi Str. 12
> >> I 39100 Bolzano/Bozen
> >> Phone: +39 0471 068611
> >> Fax: +39 0471 068619
> >> email: andreas.albarello at tol.bz.it
> >> web: http://www.tol.bz.it
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130814/7189f716/attachment-0001.html>
