[mapserver-dev] Scales and raster maps
Frank Broniewski
brfr at metrico.lu
Tue Aug 20 01:17:45 PDT 2013
Am 2013-08-09 11:40, schrieb thomas bonfort:
> Well that's where you have to factor in dpi if you want do something
> minimally generic (i don't consider passing a retina=yes or using
> different mapfiles to be a suitable solution). I've just added a
> couple of tests to show how you'd do it with mapserver, which involves
> using map.resolution (i.e. dpi) and adjusting requested image size:
> https://github.com/mapserver/msautotest/commit/715683be8f598f5e03d6e11351ccb4f8aaef23e7
> in essence
> a request for size=100,100 and resolution=144 will produce an image
> that is identical, once scaled by 50%, to an image produced with
> size=50,50 and resolution=72
Hi Thomas,
just to get back to the topic (I was on holiday last week). First, thank
you very much for writing the test - I never used this parameter
(map.resolution) before so this is really helpful for me.
So you're using the resolution parameter to scale the content/symbology
to another size. Problem I see with this is when you are using pixmap
icons / symbology. Those would get scaled up to and be blurry, wouldn't
they? That would be an argument for a separated mapfile in my point of
view. All I want to state here is that a factor (map.resolution) isn't
the solution for everything, cartography wise. You might even want to
change the font to enhance readability if you're using a retina display [1]
And again, while these are valid concerns on your behalf (including the
ones in your other posts), I'd still like to see a pixel-resolution
based parameter to help me style my layers (turn styles on or off).
This would be really helpful to synchronize other pixel-resolution based
applications with Mapserver.
While I understand that you hesitate to include another mechanism that
does more or less the same than the existing MIN- and MAXSCALEDENOM
parameters I think the effort would be fruitful. I can't be the only one
who is struggling to display the right map at a certain zoom level,
especially when you're using a chain of applications like Mapserver ->
Mapproxy -> OpenLayers.
If I'd know more about Mapservers' programming language I'd try to make
a patch for that myself, but I'm only more or less efficient with Python
and Javascript, being more a cartographer than a programmer. But if I
can do anything to help me to convince you and the team to implement
this I'd be willing to help as much as I can.
Many thanks again,
Frank
[1] http://brooksreview.net/2012/08/retina-font-choice/
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
