[mapserver-dev] MSSQL field level encryption
Tamas Szekeres
szekerest at gmail.com
Tue Aug 27 00:10:24 PDT 2013
Julien,
I think this could theoretically work by using a custom processing option
where the the decryption keys - column names are enumerated.
A MapServer-wide field decription approach may also be considered to be
implemented.
Best regards,
Tamas
2013/8/26 Julien-Samuel Lacroix <jlacroix at mapgears.com>
> Hello,
> Is it possible to use use MSSQL field level encryption with MapServer? I'm
> wondering how much of an issue to add this in the code base since it seems
> to need to send a query to open the encryption key before the actual query.
> Any idea?
> SQL Server encrypt a column of data doc:
> http://technet.microsoft.com/**en-us/library/ms179331.aspx<http://technet.microsoft.com/en-us/library/ms179331.aspx>
> Best regards,
> Julien
> Mapgears
> http://www.mapgears.com/
> ______________________________**_________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130827/aa8b0b6e/attachment.html>
