[mapserver-dev] MSSQL field level encryption
Julien-Samuel Lacroix
jlacroix at mapgears.com
Mon Aug 26 12:45:27 PDT 2013
Hello,
Is it possible to use use MSSQL field level encryption with MapServer?
I'm wondering how much of an issue to add this in the code base since it
seems to need to send a query to open the encryption key before the
actual query.
Any idea?
SQL Server encrypt a column of data doc:
http://technet.microsoft.com/en-us/library/ms179331.aspx
Best regards,
Julien
Mapgears
http://www.mapgears.com/
