[mapserver-dev] RFC-93: UTFGrid output
Francois Desjarlais
fdesjarlais1 at gmail.com
Wed Aug 28 07:18:54 PDT 2013
Hi Steve,
Yes I can add my function in mapstring.c. Will be done this day.
Regards
Francois
2013/8/28 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>
> Hi Francois: Could your JSON escaping code implemented as a utility
> function in mapstring.c? I could see some use for it in other areas (e.g.
> templating).****
> Steve****
> *From:* mapserver-dev-bounces at lists.osgeo.org [mailto:
> mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *Francois Desjarlais
> *Sent:* Wednesday, August 28, 2013 9:00 AM
> *To:* Even Rouault
> *Cc:* mapserver-dev at lists.osgeo.org; Daniel Morissette
> *Subject:* Re: [mapserver-dev] RFC-93: UTFGrid output****
> Hi Even,****
> Thanks for your feedback. ****
> I'll be looking at these points and do the necessary changes.****
> My code is already escaping non-valid characters in the JSON. It should
> always return a valid one.****
> Also, I don't have enough time to add the suggested mode before the end of
> the project and school restarting.****
> Regards****
> Francois****
> 2013/8/27 Even Rouault <even.rouault at mines-paris.org>****
> Le lundi 26 août 2013 13:06:18, Daniel Morissette a écrit :****
> > Hi Devs,
> > RFC-93 has been updated by François to reflect his implementation of
> > UTGGrid output in MapServer over the summer. Please have a look and
> > share your comments so that he has time to make any required changes
> > before the end of his project:
> > http://mapserver.org/development/rfc/ms-rfc-93.html
> > A sample app and docs are available at:
> > http://msgsoc.mapgears.com/
> > And his code is in branch utfgridgsoc of his github fork:
> > https://github.com/fdesj/mapserver/tree/utfgridgsoc****
> Nice work.
> A few points and ideas :
> * http://msgsoc.mapgears.com/html/en/output/utfgrid.html mentions
> "UTFGrids
> can be set on multiple layers but only one UTFGrid can be rendered at a
> time"
> but the RFC not. Perhaps this could be added in it too.
> * I'm wondering if the JSON escaping of values expanded in the "keys" (from
> UTFITEM) and "data" (from UTFDATA) has been taken into account (in
> particular
> escaping of " and \ ). My quick review of the code seems to indicate no,
> but I
> might be wrong.
> * perhaps there could be a mode (for the lazy folks ;-) ) in which UTFDATA
> could be generated automatically from the "gml_include_items" and
> "gml_exclude_items" layer metadata ?
> * No validation of UTFRESOLUTION is done (line 310). If set to values < 1,
> this could lead to divizon by zero or failed mallocs due to negative
> values.
> Such values shoud likely be refused.
> * r->duplicates = strcmp("false", msGetOutputFormatOption(format,
> "DUPLICATES", "true")); at line 320 is a convoluted way of writing :
> r->duplicates = EQUAL("true", msGetOutputFormatOption(format,
> "DUPLICATES",
> "true"));
> or !EQUAL("false", ... )
> * MSVC will not be happy with wchar_t string[img->width/renderer-
> >utfresolution + 1]; at line 378
> Even
> Geospatial professional services
> http://even.rouault.free.fr/services.html****
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev****
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130828/42d2227c/attachment.html>
