[mapserver-dev] Pull requests in documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Dec 4 10:14:54 PST 2013
Hi ThomasG,
I'm testing/building your branch 'branch-6-4-i18n-with-po' now. I've
checked out your branch and am following your updates/steps in
documentation.txt
I'm having trouble at the step where I believe the .mo files should be
generated. On windows, I am getting the following messages:
make compile_messages -e TRANSLATIONI18N=fr
No such file or directory: 'LC_MESSAGES\\about.mo'
No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
Indeed there are no .mo files in the folder /translated/fr/LC_MESSAGES/
(.po files do exist in /translated/fr/)
Maybe I have missed a step? Let me know what you think.
-jeff
On 2013-10-12 2:24 PM, Thomas Gratier wrote:
> Hi,
> It's done. Before i submit another PR for the documentation, you can go
> to my repository https://github.com/ThomasG77/docs.git and checkout my
> branch branch-6-4-i18n-with-po
> After, do the usual build (you need the latest Sphinx version) with make
> html to see the documentation content about documentation.
> Then, follow the instructions you have in the built html to enable the
> i18n translation process.
> If you have any feedbacks, you can do it via a Github issue , a PR or in
> this thread.
> At the end, when everything will be Ok, I will make a new PR from my
> branch, for the documentation on documentation process.
> Regards
> Thomas Gratier
