[mapserver-dev] Pull requests in documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Dec 4 11:49:45 PST 2013
Hi ThomasG,
Some more feedback for you on this issue:
- calling the python script directly generates the .mo files correctly
(python i18n_win.py --lang fr)
- if I print out the current working dir in i18n_win.py before
msgfmt.make I get:
translated\-e
So I think the options in "make compile_messages -e TRANSLATIONI18N=fr"
is having trouble on Windows.
Thoughts?
-jeff
On 2013-12-04 2:14 PM, Jeff McKenna wrote:
> Hi ThomasG,
> I'm testing/building your branch 'branch-6-4-i18n-with-po' now. I've
> checked out your branch and am following your updates/steps in
> documentation.txt
> I'm having trouble at the step where I believe the .mo files should be
> generated. On windows, I am getting the following messages:
> No such file or directory: 'LC_MESSAGES\\about.mo'
> No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
> Indeed there are no .mo files in the folder /translated/fr/LC_MESSAGES/
> (.po files do exist in /translated/fr/)
> Maybe I have missed a step? Let me know what you think.
> -jeff
> On 2013-10-12 2:24 PM, Thomas Gratier wrote:
>> Hi,
>> It's done. Before i submit another PR for the documentation, you can go
>> to my repository https://github.com/ThomasG77/docs.git and checkout my
>> branch branch-6-4-i18n-with-po
>> After, do the usual build (you need the latest Sphinx version) with make
>> html to see the documentation content about documentation.
>> Then, follow the instructions you have in the built html to enable the
>> i18n translation process.
>> If you have any feedbacks, you can do it via a Github issue , a PR or in
>> this thread.
>> At the end, when everything will be Ok, I will make a new PR from my
>> branch, for the documentation on documentation process.
>> Regards
>> Thomas Gratier
