[mapserver-dev] Pull requests in documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Dec 4 12:05:44 PST 2013
Hi ThomasG,
The following command does work here for me:
make compile_messages fr
Not sure if we should change the documentation steps to that or not.
Awaiting your advice.
-jeff
On 2013-12-04 3:49 PM, Jeff McKenna wrote:
> Hi ThomasG,
> Some more feedback for you on this issue:
> - calling the python script directly generates the .mo files correctly
> (python i18n_win.py --lang fr)
> - if I print out the current working dir in i18n_win.py before
> msgfmt.make I get:
> translated\-e
> So I think the options in "make compile_messages -e TRANSLATIONI18N=fr"
> is having trouble on Windows.
> Thoughts?
> -jeff
> On 2013-12-04 2:14 PM, Jeff McKenna wrote:
>> Hi ThomasG,
>> I'm testing/building your branch 'branch-6-4-i18n-with-po' now. I've
>> checked out your branch and am following your updates/steps in
>> documentation.txt
>> I'm having trouble at the step where I believe the .mo files should be
>> generated. On windows, I am getting the following messages:
>> No such file or directory: 'LC_MESSAGES\\about.mo'
>> No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
>> Indeed there are no .mo files in the folder /translated/fr/LC_MESSAGES/
>> (.po files do exist in /translated/fr/)
>> Maybe I have missed a step? Let me know what you think.
>> -jeff
>> On 2013-10-12 2:24 PM, Thomas Gratier wrote:
>>> Hi,
>>> It's done. Before i submit another PR for the documentation, you can go
>>> to my repository https://github.com/ThomasG77/docs.git and checkout my
>>> branch branch-6-4-i18n-with-po
>>> After, do the usual build (you need the latest Sphinx version) with make
>>> html to see the documentation content about documentation.
>>> Then, follow the instructions you have in the built html to enable the
>>> i18n translation process.
>>> If you have any feedbacks, you can do it via a Github issue , a PR or in
>>> this thread.
>>> At the end, when everything will be Ok, I will make a new PR from my
>>> branch, for the documentation on documentation process.
>>> Regards
>>> Thomas Gratier
