[mapserver-dev] Pull requests in documentation
Thomas Gratier
osgeo.mailinglist at gmail.com
Sat Dec 7 13:28:19 PST 2013
Thanks for merging my branch for internationalization.
It seems you already found an answer about the build on Windows in the
issues on Github.
I have another problem: the deployment is not working in production.
When I checkout the branch 6-4 of the docs
https://github.com/mapserver/docs/tree/branch-6-4 and do the
make compile_messages
make html
like in the script to deploy I updated
https://github.com/mapserver/docs/blob/branch-6-4/scripts/build_docs.sh
it works locally for example in the root of fr generated doc.
When I go to the http://mapserver.org/fr/index.html, the content is always
in English.
I supposed it can come from two things: the outdated version of Sphinx on
the server or/and the missing gettext packages
As I don't have access to the MapServer hosting machine, thanks for your
feedback about my concern
Cheers
Thomas Gratier
2013/12/4 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hi ThomasG,
> The following command does work here for me:
> make compile_messages fr
> Not sure if we should change the documentation steps to that or not.
> Awaiting your advice.
> -jeff
> On 2013-12-04 3:49 PM, Jeff McKenna wrote:
> > Hi ThomasG,
> > Some more feedback for you on this issue:
> > - calling the python script directly generates the .mo files correctly
> > (python i18n_win.py --lang fr)
> > - if I print out the current working dir in i18n_win.py before
> > msgfmt.make I get:
> > translated\-e
> > So I think the options in "make compile_messages -e TRANSLATIONI18N=fr"
> > is having trouble on Windows.
> > Thoughts?
> > -jeff
> > On 2013-12-04 2:14 PM, Jeff McKenna wrote:
> >> Hi ThomasG,
> >> I'm testing/building your branch 'branch-6-4-i18n-with-po' now. I've
> >> checked out your branch and am following your updates/steps in
> >> documentation.txt
> >> I'm having trouble at the step where I believe the .mo files should be
> >> generated. On windows, I am getting the following messages:
> >> No such file or directory: 'LC_MESSAGES\\about.mo'
> >> No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
> >> Indeed there are no .mo files in the folder /translated/fr/LC_MESSAGES/
> >> (.po files do exist in /translated/fr/)
> >> Maybe I have missed a step? Let me know what you think.
> >> -jeff
> >> On 2013-10-12 2:24 PM, Thomas Gratier wrote:
> >>> Hi,
> >>> It's done. Before i submit another PR for the documentation, you can go
> >>> to my repository https://github.com/ThomasG77/docs.git and checkout my
> >>> branch branch-6-4-i18n-with-po
> >>> After, do the usual build (you need the latest Sphinx version) with
> make
> >>> html to see the documentation content about documentation.
> >>> Then, follow the instructions you have in the built html to enable the
> >>> i18n translation process.
> >>> If you have any feedbacks, you can do it via a Github issue , a PR or
> in
> >>> this thread.
> >>> At the end, when everything will be Ok, I will make a new PR from my
> >>> branch, for the documentation on documentation process.
> >>> Regards
> >>> Thomas Gratier
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131207/5725751a/attachment.html>
