[mapserver-dev] Pull requests in documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Dec 9 07:04:01 PST 2013
Hello ThomasG,
When you mention that you updated the build script
(https://github.com/mapserver/docs/blob/branch-6-4/scripts/build_docs.sh) what
changes need to be made? Or maybe you can commit your changes? I can
then test on the server.
-jeff
On 2013-12-07 5:28 PM, Thomas Gratier wrote:
> Hi,
> Thanks for merging my branch for internationalization.
> It seems you already found an answer about the build on Windows in the
> issues on Github.
> I have another problem: the deployment is not working in production.
> When I checkout the branch 6-4 of the docs
> https://github.com/mapserver/docs/tree/branch-6-4 and do the
> make compile_messages
> make html
> like in the script to deploy I updated
> it works locally for example in the root of fr generated doc.
> When I go to the http://mapserver.org/fr/index.html, the content is
> always in English.
> I supposed it can come from two things: the outdated version of Sphinx
> on the server or/and the missing gettext packages
> As I don't have access to the MapServer hosting machine, thanks for your
> feedback about my concern
> Cheers
> Thomas Gratier
> 2013/12/4 Jeff McKenna <jmckenna at gatewaygeomatics.com
> <mailto:jmckenna at gatewaygeomatics.com>>
> Hi ThomasG,
> The following command does work here for me:
> make compile_messages fr
> Not sure if we should change the documentation steps to that or not.
> Awaiting your advice.
> -jeff
> On 2013-12-04 3:49 PM, Jeff McKenna wrote:
> > Hi ThomasG,
> > Some more feedback for you on this issue:
> > - calling the python script directly generates the .mo files correctly
> > (python i18n_win.py --lang fr)
> > - if I print out the current working dir in i18n_win.py before
> > msgfmt.make I get:
> > translated\-e
> > So I think the options in "make compile_messages -e
> TRANSLATIONI18N=fr"
> > is having trouble on Windows.
> > Thoughts?
> > -jeff
> > On 2013-12-04 2:14 PM, Jeff McKenna wrote:
> >> Hi ThomasG,
> >> I'm testing/building your branch 'branch-6-4-i18n-with-po' now. I've
> >> checked out your branch and am following your updates/steps in
> >> documentation.txt
> >> I'm having trouble at the step where I believe the .mo files
> should be
> >> generated. On windows, I am getting the following messages:
> >> make compile_messages -e TRANSLATIONI18N=fr
> >> No such file or directory: 'LC_MESSAGES\\about.mo'
> >> No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
> >> Indeed there are no .mo files in the folder
> /translated/fr/LC_MESSAGES/
> >> (.po files do exist in /translated/fr/)
> >> Maybe I have missed a step? Let me know what you think.
> >> -jeff
> >> On 2013-10-12 2:24 PM, Thomas Gratier wrote:
> >>> Hi,
> >>> It's done. Before i submit another PR for the documentation, you
> can go
> >>> to my repository https://github.com/ThomasG77/docs.git and
> checkout my
> >>> branch branch-6-4-i18n-with-po
> >>> After, do the usual build (you need the latest Sphinx version)
> with make
> >>> html to see the documentation content about documentation.
> >>> Then, follow the instructions you have in the built html to
> enable the
> >>> i18n translation process.
> >>> If you have any feedbacks, you can do it via a Github issue , a
> PR or in
> >>> this thread.
> >>> At the end, when everything will be Ok, I will make a new PR from my
> >>> branch, for the documentation on documentation process.
> >>> Regards
> >>> Thomas Gratier
