[mapserver-dev] Pull requests in documentation
Thomas Gratier osgeo.mailinglist at gmail.com
Mon Dec 9 09:57:42 PST 2013
Hi Jeff,
The changes are in the repository and  the branch 6.4 e.g
https://github.com/mapserver/docs/commit/366f954b59bcc18ea6ae37b1bb60342f9c23cb5cso
it's already updated.
I suppose there is a problem with deployment.
The first problem is I see the version of Sphinx is outdated on the server
(1.1.2 instead of 1.2b3, the bottom page of mapserver.org says " Created
using Sphinx <http://sphinx.pocoo.org/> 1.1.2. ")
Can you also see if in the server, you have in the clone from git, in
translated/fr/LC_MESSAGES/ a bunch of *.mo files indicating that gettext is
working well using Sphinx?
Cheers
ThomasG
2013/12/9 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Hello ThomasG,
> When you mention that you updated the build script
> (https://github.com/mapserver/docs/blob/branch-6-4/scripts/build_docs.sh)
> what
> changes need to be made?  Or maybe you can commit your changes?  I can
> then test on the server.
> -jeff
> On 2013-12-07 5:28 PM, Thomas Gratier wrote:
> > Hi,
> > Thanks for merging my branch for internationalization.
> > It seems you already found an answer about the build on Windows in the
> > issues on Github.
> > I have another problem: the deployment is not working in production.
> > When I checkout the branch 6-4 of the docs
> > https://github.com/mapserver/docs/tree/branch-6-4 and do the
> > make compile_messages
> > make html
> > like in the script to deploy I updated
> > it works locally for example in the root of fr generated doc.
> > When I go to the http://mapserver.org/fr/index.html, the content is
> > always in English.
> > I supposed it can come from two things: the outdated version of Sphinx
> > on the server or/and the missing gettext packages
> > As I don't have access to the MapServer hosting machine, thanks for your
> > feedback about my concern
> > Cheers
> > Thomas Gratier
> > 2013/12/4 Jeff McKenna <jmckenna at gatewaygeomatics.com
> > <mailto:jmckenna at gatewaygeomatics.com>>
> >     Hi ThomasG,
> >     The following command does work here for me:
> >       make compile_messages fr
> >     Not sure if we should change the documentation steps to that or not.
> >     Awaiting your advice.
> >     -jeff
> >     On 2013-12-04 3:49 PM, Jeff McKenna wrote:
> >     > Hi ThomasG,
> >     > Some more feedback for you on this issue:
> >     > - calling the python script directly generates the .mo files
> correctly
> >     > (python i18n_win.py --lang fr)
> >     > - if I print out the current working dir in i18n_win.py before
> >     > msgfmt.make I get:
> >     >   translated\-e
> >     > So I think the options in "make compile_messages -e
> >     TRANSLATIONI18N=fr"
> >     > is having trouble on Windows.
> >     > Thoughts?
> >     > -jeff
> >     > On 2013-12-04 2:14 PM, Jeff McKenna wrote:
> >     >> Hi ThomasG,
> >     >> I'm testing/building your branch 'branch-6-4-i18n-with-po' now.
>  I've
> >     >> checked out your branch and am following your updates/steps in
> >     >> documentation.txt
> >     >> I'm having trouble at the step where I believe the .mo files
> >     should be
> >     >> generated.  On windows, I am getting the following messages:
> >     >>   make compile_messages -e TRANSLATIONI18N=fr
> >     >>     No such file or directory: 'LC_MESSAGES\\about.mo'
> >     >>     No such file or directory: 'LC_MESSAGES\\announcements_all.mo'
> >     >> Indeed there are no .mo files in the folder
> >     /translated/fr/LC_MESSAGES/
> >     >> (.po files do exist in /translated/fr/)
> >     >> Maybe I have missed a step?  Let me know what you think.
> >     >> -jeff
> >     >> On 2013-10-12 2:24 PM, Thomas Gratier wrote:
> >     >>> Hi,
> >     >>> It's done. Before i submit another PR for the documentation, you
> >     can go
> >     >>> to my repository https://github.com/ThomasG77/docs.git and
> >     checkout my
> >     >>> branch branch-6-4-i18n-with-po
> >     >>> After, do the usual build (you need the latest Sphinx version)
> >     with make
> >     >>> html to see the documentation content about documentation.
> >     >>> Then, follow the instructions you have in the built html to
> >     enable the
> >     >>> i18n translation process.
> >     >>> If you have any feedbacks, you can do it via a Github issue , a
> >     PR or in
> >     >>> this thread.
> >     >>> At the end, when everything will be Ok, I will make a new PR
> from my
> >     >>> branch, for the documentation on documentation process.
> >     >>> Regards
> >     >>> Thomas Gratier
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131209/6a04c8d7/attachment.html>
