[mapserver-dev] MapScript convertToString method issue
Michel.Dastous at bentley.com Michel.Dastous at bentley.com
Fri Dec 20 11:08:51 PST 2013
All,
We are currently having issue with mapObj ::ConvertToString() method.  Reading a map file using the mapObj's constructor and immediately calling convertToString will result in a map definition with missing styles attributes.  Save() works fine with the same data.  Can anyone reproduce this issue?  Tested with version 6.4 and 6.2.
thanks
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131220/96c09609/attachment.html>
