[mapserver-dev] Version conditionals in mapfile?
Stephen Woodbridge woodbri at swoodbridge.com
Sun Dec 22 14:36:41 PST 2013
Hi all,
I want to start a discussion on the possibility of adding version
conditionals to mapfile to make it easier to support a single mapfile
across multiple versions of mapserver.
The idea would be to add some syntax that would allow something like:
IF VERSION <op> <value>
   ... use if true
ENDIF
or may be in short hand
VERSION<op>(<value>) ... use if true to end of line
or
VERSION <op> <value>? ... use if true to end of line
where <op> could be like GT|GE|EQ|LE|LT
and <value> could be VVvv or VV.vv where VV is the major version and vv
is the minor version and patch should not impact mapfile syntax so we
could ignore them.
Yes, this could be done using the C preprocessor or a script, but that
does not solve the use case of having a single file that can be deployed
and work for various versions of mapserver.
In a production environment, you might have multiple mapfiles and
multiple versions of mapserver. This would greatly simplify maintaining
the production server or migrating applications between servers that
might have different versions of mapserver installed.
Why do I care? I'm in the process of upgrading a bunch of servers and
I'm annoyed by the fact that I have 3 versions of mapserver that I need
to support and I'm having to make three separate mapfiles that are 99%
the same. Oh and this has the ripple effect that if you name these with
a version number in the mapfile name, than all the applications that
reference the mapfile have to know what version they are requesting maps
from so they can specify the correct version named mapfile.
Discussion:
Does this sound like something that would be useful to our users?
On the surface, this seems like it should be fairly easy to implemented
in the parser, but I could be wrong.
Any thoughts on this?
-Steve W
