[mapserver-dev] mapserver-dev Digest, Vol 71, Issue 17
Mark Volz
MarkVolz at co.lyon.mn.us
Mon Dec 23 12:32:26 PST 2013
Steve,
Previously I had thought that something like your idea would be useful not necessarily as a way of managing different MapServer versions, but instead as a way to manage differences different environments such as a field laptop vs production server.
For example:
MAP
#set the version near the top of the mapfile.
VERSION Laptop
#VERSION ProductionServer
IF VERSION Laptop
USE shapefiles as the data source
END IF
IF VERSION ProductionServer
User PostGIS as the data source
END IF
I think your idea is be better, but I thought I would float this idea to see if you think it would be useful.
Mark Volz, GISP
> Message: 1
> Date: Sun, 22 Dec 2013 17:36:41 -0500
> From: Stephen Woodbridge <woodbri at swoodbridge.com<mailto:woodbri at swoodbridge.com>>
> To: mapserver-dev <mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>>
> Subject: [mapserver-dev] Version conditionals in mapfile?
> Message-ID: <52B76979.6050807 at swoodbridge.com<mailto:52B76979.6050807 at swoodbridge.com>>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi all,
> I want to start a discussion on the possibility of adding version conditionals to
> mapfile to make it easier to support a single mapfile across multiple versions
> of mapserver.
> The idea would be to add some syntax that would allow something like:
> IF VERSION <op> <value>
> ... use if true
> ENDIF
> or may be in short hand
> VERSION<op>(<value>) ... use if true to end of line or VERSION <op>
> <value>? ... use if true to end of line
> where <op> could be like GT|GE|EQ|LE|LT
> and <value> could be VVvv or VV.vv where VV is the major version and vv is
> the minor version and patch should not impact mapfile syntax so we could
> ignore them.
> Yes, this could be done using the C preprocessor or a script, but that does not
> solve the use case of having a single file that can be deployed and work for
> various versions of mapserver.
> In a production environment, you might have multiple mapfiles and multiple
> versions of mapserver. This would greatly simplify maintaining the
> production server or migrating applications between servers that might have
> different versions of mapserver installed.
> Why do I care? I'm in the process of upgrading a bunch of servers and I'm
> annoyed by the fact that I have 3 versions of mapserver that I need to
> support and I'm having to make three separate mapfiles that are 99% the
> same. Oh and this has the ripple effect that if you name these with a version
> number in the mapfile name, than all the applications that reference the
> mapfile have to know what version they are requesting maps from so they
> can specify the correct version named mapfile.
> Discussion:
> Does this sound like something that would be useful to our users?
> On the surface, this seems like it should be fairly easy to implemented in the
> parser, but I could be wrong.
> Any thoughts on this?
> -Steve W
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131223/ccae838b/attachment.html>
