[mapserver-dev] Geometry operations may cause 'Unsupported GEOS geometry type' error
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Feb 20 08:35:05 PST 2013
No objection here...
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] on behalf of Tamas Szekeres [szekerest at gmail.com]
Sent: Tuesday, February 19, 2013 2:15 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Geometry operations may cause 'Unsupported GEOS geometry type' error
Hi Devs,
Certain geometry operations (like Intersection) may cause 'Unsupported GEOS geometry type' error. This is because GEOS may return geometry collections in some cases which is not supported when converting to shapeObj.
This is quite annoying for us, so I've suggested a workaround in the following issue, which provides the lines from the sub-geometries into a single shape.
https://github.com/mapserver/mapserver/issues/4591
Let me know if you have any objections to apply the fix.
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130220/a3279c6a/attachment-0001.html>
