[mapserver-dev] Disabled layers are re-enabled by wms_layer_group setting (Bug or feature?)
Stephan Meißl
stephan at meissl.name
Tue Feb 26 01:47:28 PST 2013
Tamas,
seems you hit issue #4533. I had an initial look at it but I'm currently
under heavy load and I'm afraid it has to wait a bit longer unless you
want to give it a try?
Sorry,
Stephan
On 02/26/2013 09:31 AM, Tamas Szekeres wrote:
> Hi All,
> Related to the tests of RFC-90 we found an issue when a layer is
> disabled by IP list, but for the GetCapabilities request the layer is
> re-enabled when the layer is a part of a wms_layer_group. For example
> with the following setting:
> LAYER
> NAME Layer1
> METADATA
> "ows_allowed_ip_list" "*"
> "wms_layer_group" "/Layer1"
> END
> END
> LAYER
> NAME Layer2
> METADATA
> "ows_allowed_ip_list" "!*"
> END
> END
> Both Layer1 and Layer2 are displayed in GetCapabilities. The same
> applies when the layer is completely disabled for GetCapabilities by
> enable_request, like:
> LAYER
> NAME Layer1
> METADATA
> "wms_enable_request" "GetCapabilities"
> END
> END
> LAYER
> NAME Layer2
> METADATA
> "wms_enable_request" "!GetCapabilities"
> END
> END
> Both Layer1 and Layer2 are displayed.
> Is this a feature or an issue that should be fixed?
> Best regards,
> Tamas
> 2013/2/21 Daniel Morissette <dmorissette at mapgears.com
> <mailto:dmorissette at mapgears.com>>
> On 13-02-20 10:05 AM, Tamas Szekeres wrote:
> Hi Daniel & All,
> I've updated RFC-90 to follow the concept mentioned.
> http://mapserver.org/__development/rfc/ms-rfc-90.html
> <http://mapserver.org/development/rfc/ms-rfc-90.html>
> Here is a commit containing the proposed changes according to
> the recent
> version:
> https://github.com/szekerest/__mapserver/commit/__5d7ec08292e4b790d219082f7ea6ce__d83fc5c336
> <https://github.com/szekerest/mapserver/commit/5d7ec08292e4b790d219082f7ea6ced83fc5c336>
> Thanks a lot Tamas... the RFC seems to address all my comments now.
> BTW, I notice in your commit that you call msOWSLookupMetadata()
> twice in msOWSIpDisabled():
> ip_list = msOWSLookupMetadata(metadata, namespaces,
> "allowed_ip_list");
> if (!ip_list)
> ip_list = msOWSLookupMetadata(metadata, "O", "allowed_ip_list");
> I'm not sure why you do this. FYI the idea behind
> msOWSLookupMetadata() is that all places that pass a "namespaces"
> arg should include the "O" as the last argument in the string... so
> your second call with the "O" is redundant unless I'm mistaken since
> the namespaces in the previous call should contain an "O" already.
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> _________________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
> <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
