[mapserver-dev] Disabled layers are re-enabled by wms_layer_group setting (Bug or feature?)
Tamas Szekeres
szekerest at gmail.com
Tue Feb 26 04:09:32 PST 2013
Stephan,
I wonder why did I miss that bug. I'll be trying to find a fix.
Best regards,
Tamas
2013/2/26 Stephan Meißl <stephan at meissl.name>
> Tamas,
> seems you hit issue #4533. I had an initial look at it but I'm currently
> under heavy load and I'm afraid it has to wait a bit longer unless you
> want to give it a try?
> Sorry,
> Stephan
> On 02/26/2013 09:31 AM, Tamas Szekeres wrote:
> > Hi All,
> > Related to the tests of RFC-90 we found an issue when a layer is
> > disabled by IP list, but for the GetCapabilities request the layer is
> > re-enabled when the layer is a part of a wms_layer_group. For example
> > with the following setting:
> > LAYER
> > NAME Layer1
> > METADATA
> > "ows_allowed_ip_list" "*"
> > "wms_layer_group" "/Layer1"
> > END
> > END
> > LAYER
> > NAME Layer2
> > METADATA
> > "ows_allowed_ip_list" "!*"
> > END
> > END
> > Both Layer1 and Layer2 are displayed in GetCapabilities. The same
> > applies when the layer is completely disabled for GetCapabilities by
> > enable_request, like:
> > LAYER
> > NAME Layer1
> > METADATA
> > "wms_enable_request" "GetCapabilities"
> > END
> > END
> > LAYER
> > NAME Layer2
> > METADATA
> > "wms_enable_request" "!GetCapabilities"
> > END
> > END
> > Both Layer1 and Layer2 are displayed.
> > Is this a feature or an issue that should be fixed?
> > Best regards,
> > Tamas
> > 2013/2/21 Daniel Morissette <dmorissette at mapgears.com
> > <mailto:dmorissette at mapgears.com>>
> > On 13-02-20 10:05 AM, Tamas Szekeres wrote:
> > Hi Daniel & All,
> > I've updated RFC-90 to follow the concept mentioned.
> > http://mapserver.org/__development/rfc/ms-rfc-90.html
> > <http://mapserver.org/development/rfc/ms-rfc-90.html>
> > Here is a commit containing the proposed changes according to
> > the recent
> > version:
> https://github.com/szekerest/__mapserver/commit/__5d7ec08292e4b790d219082f7ea6ce__d83fc5c336
> https://github.com/szekerest/mapserver/commit/5d7ec08292e4b790d219082f7ea6ced83fc5c336
> > Thanks a lot Tamas... the RFC seems to address all my comments now.
> > BTW, I notice in your commit that you call msOWSLookupMetadata()
> > twice in msOWSIpDisabled():
> > ip_list = msOWSLookupMetadata(metadata, namespaces,
> > "allowed_ip_list");
> > if (!ip_list)
> > ip_list = msOWSLookupMetadata(metadata, "O", "allowed_ip_list");
> > I'm not sure why you do this. FYI the idea behind
> > msOWSLookupMetadata() is that all places that pass a "namespaces"
> > arg should include the "O" as the last argument in the string... so
> > your second call with the "O" is redundant unless I'm mistaken since
> > the namespaces in the previous call should contain an "O" already.
> > Daniel Morissette
> > http://www.mapgears.com/
> > Provider of Professional MapServer Support since 2000
> > _________________________________________________
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> > http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
> > <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130226/17a19c08/attachment-0001.html>
