[mapserver-dev] Call for vote on RFC 100
Even Rouault even.rouault at mines-paris.org
Fri Jul 5 07:47:12 PDT 2013
Selon Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> > On 13-07-04 1:59 PM, Even Rouault wrote:
> >> Hi PSC,
> >> If there are not any additional comments, I'd like to call for a vote
> >> on RFC
> >> 100 ( http://mapserver.org/en/development/rfc/ms-rfc-100.html ), which
> >> adds
> >> support for tile index with mixed SRS in raster layers.
> +1
> I feel this is very needed.   Power users often let me know about this
> SRS issue for large mapping areas. Another issue I hear constantly from
> these same power users is the problem of opening up too many files in
> these tile indexes (subsequently bogging down MapServer).  Keep that
> issue on the backburner, for a 'rainy day'.
If the problem is that opening many files is slow, I'm not sure what can be done
on this. Apart from reducing the number of files by mosaicing the ones that can
be mosaiced. Normally for a display window of reasonable size, you shouldn't
have too have that many files. Except if you zoom out and that no overviews have
been created. And if you create overviews, you should consider creating
overviews not on each tile, but on the mosaic.
> -jeff
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
