[mapserver-dev] GSoC UTFGrid Project
thomas bonfort thomas.bonfort at gmail.com
Sat Jul 6 02:50:20 PDT 2013
Hi Francois, welcome to the team!
Here are a few comments regarding the code you have published in your branch:
- Why are you adding a UTFGRID entry to MS_LAYER_TYPES? Layer types
should not need to be extended as utgfgrid is an outputformat that
should apply to existing layers.
- Using aggFakeOutput  inside your UTFGridRenderer does not seem like
the way to go. I believe you should be creating a full-fledged
outputformat with its own rendererVtable
- why the WITH_AGG_ALIASED option to cmake? You'll need a specific agg
renderer for utfgrid support (which you are correct will need to be
aliased). The only cmake option I would see would be to eventually be
able to disable utfgrid support completely (and given that there
should be no dependencies, I'm not sure that is needed).
- you must not export a "rasterbuffer" and add code to mapimageio.c
for saving as json. Implement your own saving functions inside the
utfgrid renderervtable. (c.f. the vector vtables in mapcairo.c), and
publicize you do not support a rasterbuffer.
- you should not be messing with map->cellsize, scale, width, height,
etc... inside mapdraw.c. Your utfRes adjustments should be private to
the utfrenderer.
cheers,
thomas
On 5 July 2013 21:36, Francois Desjarlais <fdesjarlais1 at gmail.com> wrote:
> Hi everybody!
> Like Daniel said I'm François Desjarlais, 3rd year computer engineering
> student. I just wanted to add a little something to what Daniel wrote.
> Instead of mapbox example, you can look at my own example on
> http://msgsoc.mapgears.com/projet_utfgrid/testhtmlmapserver.html. It's a bit
> buggy right now but as summer will go on it will get better.
> Also, I have a question. Daniel told me that Steve Lime could answer:
> Steve,
> What is UTFITEM function? I read the RFC-93 multiple times and I can't
> figure what it does. It's doing the same thing as UTFDATA because datas are
> linked with shapes. And if you don't need certain datas you just remove them
> from UTFDATA instead of adding syntax with UTFITEM.
> Thanks!
> Francois
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
