[mapserver-dev] Template driven output - issue with PostGIS connection
Havard Tveite
havard.tveite at umb.no
Thu Jun 6 04:49:04 PDT 2013
I have not tried with other data sources, so this may not be
PostGIS related.
I have sent Thomas the information from the PostgreSQL logs
(the queries seemed to be the same for GML and geojson).
Håvard
On 6/6/2013 1:26 PM, thomas bonfort wrote:
> Havard,
> The postgis driver hasn't changed in trunk since 6.2. Can you enable debugging on your postgis layer and post the query that is being sent to the postgres backend?
> regards,
> thomas
> On 6 June 2013 13:17, Havard Tveite <havard.tveite at umb.no <mailto:havard.tveite at umb.no>> wrote:
> I have a PostGIS connection, and want to provide GeoJSON
> output.
> After some stumbling (and updating of the Mapserver docs!),
> I got it to work, except for the "using unique" part.
> The interesting parts of my DATA string is like:
> DATA "geom from (select x.id <http://x.id> as id, ...) as test using unique id using SRID=4326"
> This works well for WFS with GML, but when I add
> "&outputformat=geojson" (to get GeoJSON output), the returned
> id is a very large number (for instance 137051404431549 - it
> changes for each request), and it is the same number for all
> the features. The actual ids are between 1 and 1000.
> I have the same issue when not using WFS (&mode=nquery&qformat=geojson)__.
> My template for geojson output is according to the documentation
> (and everything else is returned as it should).
> Could this be a bug?
> mapserv -v
> MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=OPENGL SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I have not checked trunk.
> Håvard
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 <tel:%2B47%2064965483> Fax: +47 64965401 <tel:%2B47%2064965401> http://www.umb.no/imt/
> _________________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> http://lists.osgeo.org/__mailman/listinfo/mapserver-dev <http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
Håvard Tveite
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
