[mapserver-dev] Template driven output - issue with PostGIS connection
Smith, Michael ERDC-RDE-CRREL-NH
Michael.Smith at erdc.dren.mil
Thu Jun 6 05:00:02 PDT 2013
You could also try to isolate it to the template output by trying ogr
based geojson output (http://mapserver.org/output/ogr_output.html)
OUTPUTFORMAT
NAME "OGR_GeoJson"
DRIVER "GeoJson"
FORMATOPTION "STORAGE=stream"
FORMATOPTION "FORM=simple"
END
Mike
On 6/6/13 7:49 AM, "Havard Tveite" <havard.tveite at umb.no> wrote:
>I have not tried with other data sources, so this may not be
>PostGIS related.
>I have sent Thomas the information from the PostgreSQL logs
>(the queries seemed to be the same for GML and geojson).
>Håvard
>On 6/6/2013 1:26 PM, thomas bonfort wrote:
>> Havard,
>> The postgis driver hasn't changed in trunk since 6.2. Can you enable
>>debugging on your postgis layer and post the query that is being sent to
>>the postgres backend?
>> regards,
>> thomas
>> On 6 June 2013 13:17, Havard Tveite <havard.tveite at umb.no
>><mailto:havard.tveite at umb.no>> wrote:
>> I have a PostGIS connection, and want to provide GeoJSON
>> output.
>> After some stumbling (and updating of the Mapserver docs!),
>> I got it to work, except for the "using unique" part.
>> The interesting parts of my DATA string is like:
>> DATA "geom from (select x.id <http://x.id> as id, ...) as test
>>using unique id using SRID=4326"
>> This works well for WFS with GML, but when I add
>> "&outputformat=geojson" (to get GeoJSON output), the returned
>> id is a very large number (for instance 137051404431549 - it
>> changes for each request), and it is the same number for all
>> the features. The actual ids are between 1 and 1000.
>> I have the same issue when not using WFS
>>(&mode=nquery&qformat=geojson)__.
>> My template for geojson output is according to the documentation
>> (and everything else is returned as it should).
>> Could this be a bug?
>> mapserv -v
>> MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>>SUPPORTS=OPENGL SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>>SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>>INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> I have not checked trunk.
>> Håvard
>> Håvard Tveite
>> Department of Mathematical Sciences and Technology, UMB
>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
>> Phone: +47 64965483 <tel:%2B47%2064965483> Fax: +47 64965401
>><tel:%2B47%2064965401> http://www.umb.no/imt/
>> _________________________________________________
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>> http://lists.osgeo.org/__mailman/listinfo/mapserver-dev
>><http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>Håvard Tveite
>Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
