[mapserver-dev] Layer names in OGR connection strings (undocumented feature causing problems)
Tamas Szekeres
szekerest at gmail.com
Tue Mar 5 00:03:00 PST 2013
Good point about quoting the connection string. That seems to work it
around. Thanks.
Best regards,
Tamas
2013/3/5 Daniel Morissette <dmorissette at mapgears.com>
> Note that since the parsing code uses CSLTokenizeStringComplex(), in the
> case of OCI connections (below) and the example from
> http://trac.osgeo.org/gdal/**ticket/4885<http://trac.osgeo.org/gdal/ticket/4885>one could likely work around the issue by enclosing the first part of the
> connection string inside quotes, e.g.
> CONNECTION '"OCI:userid/password@**database_instance:table,table"**
> ,ogr_layer_id'
> I realize that dealing with string escaping this way is nasty and may not
> work for all cases.
> I am not sure about the impact of removing support for this way to specify
> the ogr layer id which I knew about as well without knowing whether it was
> documented or not. It's really hard to tell how many users have come to
> rely on it over time and I'd hate to break backwards compatibility if we
> can avoid it.
> Daniel
> On 13-03-04 5:29 PM, Smith, Michael ERDC-CRREL-NH wrote:
>> Comma separated table names is also part of the OCI connection
>> "OCI:userid/password at database_**instance:table,table"
>> http://www.gdal.org/ogr/drv_**oci.html<http://www.gdal.org/ogr/drv_oci.html>
>> From: Brent Fraser <bfraser at geoanalytic.com
>> <mailto:bfraser at geoanalytic.**com <bfraser at geoanalytic.com>>>
>> Organization: GeoAnalytic Inc.
>> Date: Monday, March 4, 2013 5:25 PM
>> To: Tamas Szekeres <szekerest at gmail.com <mailto:szekerest at gmail.com>>
>> Cc: "mapserver-dev at lists.osgeo.org
>> <mailto:mapserver-dev at lists.**osgeo.org <mapserver-dev at lists.osgeo.org>>"
>> <mailto:mapserver-dev at lists.**osgeo.org <mapserver-dev at lists.osgeo.org>>>
>> Subject: Re: [mapserver-dev] Layer names in OGR connection strings
>> Resent-From: Michael Smith <michael.smith at usace.army.mil
>> <mailto:michael.smith at usace.**army.mil <michael.smith at usace.army.mil>>>
>> Tamas,
>> No doc that I know of. I knew of the technique of adding
>> comma-separated table names to connection strings from years ago when I
>> was trying to improve the performance of an ODBC connection
>> (http://www.gdal.org/ogr/drv_**odbc.html<http://www.gdal.org/ogr/drv_odbc.html>).
>> Stating the table names
>> relieves the driver from enumerating all the tables (and views etc) in
>> the schema. Maybe I had reviewed the source code; I can't recall...
>> Best Regards,
>> Brent Fraser
>> On 3/4/2013 2:20 PM, Tamas Szekeres wrote:
>>> Brent,
>>> Could you point me to the documentation where this syntax is
>>> mentioned? Is this specific to OGR tile indexes?
>>> Best regards,
>>> Tamas
>>> 2013/3/3 Brent Fraser <bfraser at geoanalytic.com
>>> Tamas,
>>> if I understand correctly you are talking about connection
>>> strings like:
>>> CONNECTIONTYPE OGR
>>> TILEINEX "PG:dbname='PN2010_0911' host='thinkcentre1'
>>> port='5432' user='PN2010_0911' password='PN2010_0911',images"
>>> note the comma and table name at the end.
>>> See
>>> http://lists.osgeo.org/**pipermail/mapserver-dev/2011-**
>>> April/011194.html<http://lists.osgeo.org/pipermail/mapserver-dev/2011-April/011194.html>
>>> Best Regards,
>>> Brent Fraser
>>> On 3/3/2013 2:09 PM, Tamas Szekeres wrote:
>>>> Hi,
>>>> According to a commit (made 11 years ago) in rev1370
>>>> <http://trac.osgeo.org/**mapserver/changeset/1370<http://trac.osgeo.org/mapserver/changeset/1370>>
>>>> the OGR
>>>> connections strings are being split by the comma separators, see
>>>> the following fragment in msOGRFileOpen:
>>>> papszTokens = CSLTokenizeStringComplex( conn_decrypted, ",",
>>>> TRUE, FALSE );
>>>> if( CSLCount(papszTokens) > 0 )
>>>> pszDSName = CPLStrdup( papszTokens[0] );
>>>> if( CSLCount(papszTokens) > 1 )
>>>> pszLayerDef = CPLStrdup( papszTokens[1] );
>>>> This behaviour causes issues if the syntax of the connection
>>>> string may normally expect commas, like with the issue:
>>>> Does it make sense to split the connection strings this way?
>>>> According to the OGR driver documentation
>>>> <http://mapserver.org/en/**input/vector/ogr.html<http://mapserver.org/en/input/vector/ogr.html>>
>>>> the layer
>>>> definitions should go to the DATA section and not to the
>>>> CONNECTION section.
>>>> I'd be in favour of removing this fragment from the code but I'm
>>>> not sure about all consequences.
>>>> Best regards,
>>>> Tamas
>>>> ______________________________**_________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.**
>>>> osgeo.org <mapserver-dev at lists.osgeo.org>>http://lists.osgeo.**
>>>> org/mailman/listinfo/**mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-dev<http://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130305/d6245d12/attachment-0001.html>
