[mapserver-dev] Layer names in OGR connection strings (undocumented feature causing problems)
Daniel Morissette
dmorissette at mapgears.com
Tue Mar 5 05:22:36 PST 2013
On 13-03-04 9:13 PM, Stephen Woodbridge wrote:
> Daniel,
> I have never used either of these, which I probably why I am unaware of
> it, but the original implementation seems very hackish at best. Maybe
> implementing something more formal like:
> PROCESSING TABLES=tab1,tab2,...
No need for a new PROCESSING directive, the documented way to connect to
OGR data sources is to use:
LAYER
CONNECTIONTYPE OGR
CONNECTION "<datasource_name>"
DATA "<layer_definition>"
END
http://mapserver.org/input/vector/ogr.html#using-ogr-data-sources-in-the-map-file
The question is really whether we should keep the undocumented shortcut
(CONNECTION "<datasource_name>,<layer_definition>") which was likely
introduced to support TILEINDEX on OGR data sources.
Maybe Frank can comment if he reads this.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
