[mapserver-dev] Testing infrastructure?
Tamas Szekeres szekerest at gmail.com
Thu Mar 7 02:48:26 PST 2013
2013/3/7 thomas bonfort <thomas.bonfort at gmail.com>
> > I thought Thomas set up a build bot that built and tested on multiple
> > systems, but I'm drawing a blank on that. Can you point me to some links
> for
> > how to do that. Also is it possible to get the build bot to do windows
> > builds using MinGW/MSYS, if you know?
> I'll let Tamas comment on the windows part.
> For linux, the testsuite could be run on travis-ci (you can find the
> configuration for it in the .travis.yaml file in our repo). We/I
> switched to using a self hosted jenkins instance as the travis service
> tended to be a bit more unreliable (false positives generated by the
> travis infrastructure rather than our own code) and slower (as the
> system dependencies need to be re-installed for each run. travis runs:
> ~4min30sec; jenkins:~1min30sec)
The Windows buildsystem at http://www.gisinternals.com/sdk/ runs msautotest
as part of the build process. You may inspect the results by clicking on
the msautotest link from the start page.
However I had to disable the wxs tests since it was hanging with all
configurations. This may be due to a memory corruption problem which I
still didn't have the chance to track it down.
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130307/878a4598/attachment.html>
