[mapserver-dev] R: R: Re: loadWeb(): Unknown identifier
francescoboccacci at libero.it
Wed Mar 13 07:27:56 PDT 2013
Hi all,
any suggestion about POST problem?
I use Firebug and it seems that post parameters are passed in right way.
Thanks
Francesco
>----Messaggio originale----
>Da: francescoboccacci at libero.it
>Data: 10/03/2013 23.31
>A: <jmckenna at gatewaygeomatics.com>, <mapserver-dev at lists.osgeo.org>
>Ogg: [mapserver-dev] R: Re: loadWeb(): Unknown identifier
>Hi Jeff,
>i tried to remove :
>'<input type="hidden"
>>name="map_web_imagepath" value="/var/www/mapserver/tmp/">
> <!-- MapServer Template -->
><html>
><head><title>MapServer Hello World</title></head>
><body>
><form method="GET" action="/cgi-bin/mapserv">
><input type="submit" value="Click Me">
><input type="hidden" name="map" value="/var/www/mapserver/hello.map">
></form>
><IMG SRC="[img]" width=400 height=300 border=0>
></body>
></html>
>and change method from POST to GET and it works.
>If i use method POST it seems it doesn't works.
><html>
><body>
><form method="POST" action="/cgi-bin/mapserv">
></form>
></body>
></html>
>msOWSPreParseRequest(): OWS error. POST request is empty.
>Any suggestions?
>Thanks
>Francesco
>>Da: jmckenna at gatewaygeomatics.com
>>Data: 10/03/2013 22.12
>>A: <mapserver-dev at lists.osgeo.org>
>>Ogg: Re: [mapserver-dev] loadWeb(): Unknown identifier
>>On 2013-03-09 11:48 AM, francescoboccacci at libero.it wrote:
>>> during a test i receive the follow error:
>>> loadWeb(): Unknown identifier. Parsing error near
>(/var/www/mapserver/tmp/):
>>> (line 1)
>>I hit this issue very often. Error line 1 is a sign that there is a
>>problem with the way the old CGI template is passing parameters to
>>mapserv. This has to do with changes made to MapServer 5.0 in how to
>>pass parameters (give a good read to:
>>http://www.mapserver.org/cgi/controls.html#using-mapserver-version-5)
>>You might try even removing your whole line '<input type="hidden"
>>name="map_web_imagepath" value="/var/www/mapserver/tmp/">' or changing
>>it to match the correct syntax.
>>Happy sunny Sunday to all.
>>-jeff
>>Jeff McKenna
>>MapServer Consulting and Training Services
>>http://www.gatewaygeomatics.com/
>>_______________________________________________
>>mapserver-dev mailing list
>>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
