[mapserver-dev] Request for review/comments on RFC 85 (Contour Layer Rendering)
Alan Boudreault
aboudreault at mapgears.com
Tue Mar 26 05:21:48 PDT 2013
Brent, yes, that's what I mean in my first point.. but typo. * the
connectiontype use will be kept*... until we define another way for
hybrid layers.
Thanks
Alan
On 13-03-25 10:07 PM, Brent Fraser wrote:
> So we're sticking with the "CONNECTIONTYPE CONTOUR"?
> Best Regards,
> Brent Fraser
> On 3/25/2013 1:22 PM, Alan Boudreault wrote:
>> Dev,
>> I would like to do the inclusion this week. A few comments about the
>> current implementation:
>> - For now, I think the contourlayer use will be kept, we will need to
>> think more about hybrid layers for mapserver 6.4.
>> - Tileindex are not supported (yet)
>> - Postgis raster are not supported (yet)
>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html
>> I'll do the call for vote tomorrow morning if there's no objection.
>> Alan
>> On 12-09-21 03:22 AM, Havard Tveite wrote:
>>> I am not sure if contour generation should be a job for Mapserver,
>>> but if we decide to implement it, I think there is a need for
>>> processing directives for "smoothing" / generalisation.
>>> It should be possible to specify the level of "smoothing" for the
>>> DEM as well as for the resulting contours.
>>> Smoothing levels could be specified as the maximum deviation
>>> allowed from the "original".
>>> Contour "smoothing" / generalisation needs to pay attention to
>>> neighbouring contours / topology, so that contours don't cross
>>> after smoothing.
>>> Possible processing directives for a DEM tolerance of 25 units
>>> (xyz) and contour tolerance of 10 units (xy):
>>> PROCESSING "DEM_TOLERANCE"=25"
>>> PROCESSING "CONTOUR_TOLERANCE=10"
>>> They could be made scale dependent in the way that is suggested
>>> in the RFC.
>>> "TOLERANCE" might not be the best word - "GENERALIZATION"
>>> is also be a possibility.
>>> It would also be good to choose an approach that will not
>>> make it impossible to use a point layer (xyz or xy+height
>>> attribute) as a data source.
>>> Håvard
>>> On 9/20/2012 5:40 PM, Alan Boudreault wrote:
>>>> Hi devs,
>>>> I'd like to request some review on a pending RFC regarding support for
>>>> contour layer rendering.
>>>> Please see
>>>> https://raw.github.com/mapserver/docs/master/en/development/rfc/ms-rfc-85.txt
>>>> The official rfc page should be updated in about a hour.
>>>> http://mapserver.org/trunk/development/rfc/ms-rfc-85.html.
>>>> Thanks,
>>>> Alan
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Alan Boudreault
http://www.mapgears.com/
