[mapserver-dev] Issue with CMAKE plugin build
    thomas bonfort
    thomas.bonfort at gmail.com
    Sun Mar 31 13:33:08 PDT 2013
Tamas,
If the user wants the oracle plugin, do I have this correct:
- libmapserver should be compiled without oracle support at all
- a module should be built containing just the code from
maporaclespatial.c, compiled with USE_ORACLE=1 and USE_ORACLE_PLUGIN=1
thomas
On 31 March 2013 15:22, Tamas Szekeres <szekerest at gmail.com> wrote:
> I also think both USE_ORACLESPATIAL  and USE_ORACLE_PLUGIN should be set
> to 1 but it should be set only when compiling the oraclespatial plugin
> component, not the core mapserver. In the core mapserver compilation when
> the user sets USE_ORACLE_PLUGIN=1 we should implicitly
> set USE_ORACLESPATIAL=0 to avoid the inclusion of the oci code. However in
> the plugin module we should keep both settings to 1. Since I'm not a cmake
> guru, do we have a simple solution to achieve this result?
> Best regards,
> Tamas
> 2013/3/31 thomas bonfort <thomas.bonfort at gmail.com>
>> Tamas,
>> From the code in maporaclespatial.c both USE_ORACLESPATIAL and
>> USE_ORACLE_PLUGIN need to be defined in order for some of the needed code
>> to be activated. As there's no reference to the oracle_plugin stuff in the
>> unix makefiles, I'll infer that this is a windows only feature and suppose
>> that you can handle the dependencies in the cmake files as you wish.
>> regards,
>> thomas
>> On 31 March 2013 12:26, Tamas Szekeres <szekerest at gmail.com> wrote:
>>> I wanted to build mapserver with oraclespatial support to compile
>>> oraclespatial as a plugin, but that doesn't seem to work.
>>> Actually when setting WITH_ORACLE_PLUGIN=1, I also require to set
>>>  WITH_ORACLESPATIAL=1 which causes that oracle is being built in mapserver
>>> directly. However, I don't want to build oracle in mapserver directly, just
>>> compile the oracle plugin (dll).
>>> IMHO we should be able to set the combination: WITH_ORACLESPATIAL=0 and
>>> WITH_ORACLE_PLUGIN=1. In this case we should get an additional module
>>> generated by cmake to compile the oracle plugin separately.
>>> The same should apply to the SDE and MSSQL plugins too.
>>> Best regards,
>>> Tamas
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130331/ec2eee9e/attachment.html>
