[mapserver-dev] Request for review/comments on RFC 85 (Contour Layer Rendering)
Brent Fraser
bfraser at geoanalytic.com
Tue Mar 26 11:55:39 PDT 2013
Hmmm. How about:
- All other layers are to be ignored (rendered normally)
- generate (but don't yet render) the contour lines
- generate the labels (consider the labelcache?) using the contour
lines, compute the label bounding boxes
- clip the contour lines to the bounding boxes, render the
remaining line segments
- render the labels
I've attached a snap from an NRCan CanTopo...
Best Regards,
Brent Fraser
On 3/26/2013 12:35 PM, Daniel Morissette wrote:
> On 13-03-26 2:20 PM, Brent Fraser wrote:
>> Something for future consideration: contour labeling - blanking/clipping
>> contour lines (but not other features) under the bound box of the
>> contour labels.
> Hi Brent,
> We just discussed this here... that would be nice, but a bit expensive
> to do on the fly as you would need to perform all collision detection
> (across all layers with labels) before rendering the contour lines,
> likely requiring multiple passes on the data. We got answers around
> the table ranging from "just use an opaque BG color for the label
> (geomtransform labelpoly)" to "anything is possible given enough time
> and money". :-)
> Cheers
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130326/0935a16e/attachment-0001.png>
