[mapserver-dev] Pull requests in documentation
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Oct 10 10:12:16 PDT 2013
Ok thank you Thomas.
-jeff
On 2013-10-10 12:58 PM, Thomas Gratier wrote:
> Hi,
> Jeff, Yves, I will finish and push the docs about the new system this week.
> Thomas Gratier (author of the two mentioned PR)
> 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
> <mailto:yves.jacolin at camptocamp.com>>
>     Thanks Jeff!
>     Y.
>     2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com
>     <mailto:jmckenna at gatewaygeomatics.com>>:
>     > I want to test this before merging.  I will do so and get back to you.
>     > -jeff
>     > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
>     >> Hello,
>     >> There are 4 pull requests [1] whit 2 of them look important to me
>     (I18n system
>     >> and i18n pot file) as it can help to improve the translation process.
>     >> QGIS is using such system successfully with transiflex app which
>     helps to get
>     >> website and documentation translated really fast.
>     >> I do think that this 2 PR are worth to be merged into master branch.
>     >> I would like to get your opinion (Jeff :) ) on this, may be we
>     can run a short
>     >> vote after discussion. I know that there are some discussion on
>     this on the
>     >> FOSS4G code sprint but may be a broader discussion could help.
>     >> Thanks, :)
>     >> Y.
>     >> [1] https://github.com/mapserver/docs/pulls
>     > _______________________________________________
>     > mapserver-dev mailing list
>     > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     Responsable Formation et Support
>     Camptocamp France SAS
>     Savoie Technolac, BP 352
>     73377 Le Bourget du Lac, Cedex
>     Tel (France) : +33 4 79 26 57 98 <tel:%2B33%204%2079%2026%2057%2098>
>     Tel (Suisse) : 021 619 10 43
>     Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
>     Fax : 04 79 70 15 81
