[mapserver-dev] Pull requests in documentation
Thomas Gratier
osgeo.mailinglist at gmail.com
Sat Oct 12 10:24:26 PDT 2013
It's done. Before i submit another PR for the documentation, you can go to
my repository https://github.com/ThomasG77/docs.git and checkout my branch
branch-6-4-i18n-with-po
After, do the usual build (you need the latest Sphinx version) with make
html to see the documentation content about documentation.
Then, follow the instructions you have in the built html to enable the i18n
translation process.
If you have any feedbacks, you can do it via a Github issue , a PR or in
this thread.
At the end, when everything will be Ok, I will make a new PR from my
branch, for the documentation on documentation process.
Regards
Thomas Gratier
2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Ok thank you Thomas.
> -jeff
> On 2013-10-10 12:58 PM, Thomas Gratier wrote:
> > Hi,
> > Jeff, Yves, I will finish and push the docs about the new system this
> week.
> > Thomas Gratier (author of the two mentioned PR)
> > 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
> > <mailto:yves.jacolin at camptocamp.com>>
> > Thanks Jeff!
> > Y.
> > <mailto:jmckenna at gatewaygeomatics.com>>:
> > > I want to test this before merging. I will do so and get back to
> you.
> > > -jeff
> > > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
> > >> Hello,
> > >> There are 4 pull requests [1] whit 2 of them look important to me
> > (I18n system
> > >> and i18n pot file) as it can help to improve the translation
> process.
> > >> QGIS is using such system successfully with transiflex app which
> > helps to get
> > >> website and documentation translated really fast.
> > >> I do think that this 2 PR are worth to be merged into master
> branch.
> > >> I would like to get your opinion (Jeff :) ) on this, may be we
> > can run a short
> > >> vote after discussion. I know that there are some discussion on
> > this on the
> > >> FOSS4G code sprint but may be a broader discussion could help.
> > >> Thanks, :)
> > >> Y.
> > >> [1] https://github.com/mapserver/docs/pulls
> > > _______________________________________________
> > > mapserver-dev mailing list
> > > mapserver-dev at lists.osgeo.org <mailto:
> mapserver-dev at lists.osgeo.org>
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> > Responsable Formation et Support
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel (France) : +33 4 79 26 57 98 <tel:%2B33%204%2079%2026%2057%2098>
> > Tel (Suisse) : 021 619 10 43
> > Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
> > Fax : 04 79 70 15 81
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131012/f3076423/attachment.html>
