[mapserver-dev] Pull requests in documentation
Yves Jacolin
yves.jacolin at camptocamp.com
Sun Oct 13 13:23:16 PDT 2013
Thomas,
I built the french translation on my system which seems quiet simple
and your doc is enought to find the good way (except some english
misleading).
Thanks,
Y.
2013/10/12 Thomas Gratier <osgeo.mailinglist at gmail.com>:
> Hi,
> It's done. Before i submit another PR for the documentation, you can go to
> my repository https://github.com/ThomasG77/docs.git and checkout my branch
> branch-6-4-i18n-with-po
> After, do the usual build (you need the latest Sphinx version) with make
> html to see the documentation content about documentation.
> Then, follow the instructions you have in the built html to enable the i18n
> translation process.
> If you have any feedbacks, you can do it via a Github issue , a PR or in
> this thread.
> At the end, when everything will be Ok, I will make a new PR from my branch,
> for the documentation on documentation process.
> Regards
> Thomas Gratier
> 2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
>> Ok thank you Thomas.
>> -jeff
>> On 2013-10-10 12:58 PM, Thomas Gratier wrote:
>> > Hi,
>> > Jeff, Yves, I will finish and push the docs about the new system this
>> > week.
>> > Thomas Gratier (author of the two mentioned PR)
>> > 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
>> > <mailto:yves.jacolin at camptocamp.com>>
>> > Thanks Jeff!
>> > Y.
>> > <mailto:jmckenna at gatewaygeomatics.com>>:
>> > > I want to test this before merging. I will do so and get back to
>> > you.
>> > > -jeff
>> > > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
>> > >> Hello,
>> > >> There are 4 pull requests [1] whit 2 of them look important to me
>> > (I18n system
>> > >> and i18n pot file) as it can help to improve the translation
>> > process.
>> > >> QGIS is using such system successfully with transiflex app which
>> > helps to get
>> > >> website and documentation translated really fast.
>> > >> I do think that this 2 PR are worth to be merged into master
>> > branch.
>> > >> I would like to get your opinion (Jeff :) ) on this, may be we
>> > can run a short
>> > >> vote after discussion. I know that there are some discussion on
>> > this on the
>> > >> FOSS4G code sprint but may be a broader discussion could help.
>> > >> Thanks, :)
>> > >> Y.
>> > >> [1] https://github.com/mapserver/docs/pulls
>> > > _______________________________________________
>> > > mapserver-dev mailing list
>> > > mapserver-dev at lists.osgeo.org
>> > <mailto:mapserver-dev at lists.osgeo.org>
>> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> > Responsable Formation et Support
>> > Camptocamp France SAS
>> > Savoie Technolac, BP 352
>> > 73377 Le Bourget du Lac, Cedex
>> > Tel (France) : +33 4 79 26 57 98 <tel:%2B33%204%2079%2026%2057%2098>
>> > Tel (Suisse) : 021 619 10 43
>> > Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
>> > Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
