[mapserver-dev] Pull requests in documentation
Thomas Gratier osgeo.mailinglist at gmail.com
Mon Oct 28 14:50:05 PDT 2013
I'm always waiting for my PR to be merged.
Any new about this?
Jeff, did you try to build the French documentation using my branch?
It's a 10 min try FYI.
Thanks for your feedback
Cheers
Thomas
2013/10/14 Thomas Gratier <osgeo.mailinglist at gmail.com>
> Hi,
> Thanks for the first feedback.Can you tell where are the "english
>  misleading"? I want to make required modifications to make things more
> clear.
> Thanks
> Thomas
> 2013/10/13 Yves Jacolin <yves.jacolin at camptocamp.com>
>> Thomas,
>> I built the french translation on my system which seems quiet simple
>> and your doc is enought to find the good way (except some english
>> misleading).
>> Thanks,
>> Y.
>> 2013/10/12 Thomas Gratier <osgeo.mailinglist at gmail.com>:
>> > Hi,
>> > It's done. Before i submit another PR for the documentation, you can go
>> to
>> > my repository https://github.com/ThomasG77/docs.git and checkout my
>> branch
>> > branch-6-4-i18n-with-po
>> > After, do the usual build (you need the latest Sphinx version) with make
>> > html to see the documentation content about documentation.
>> > Then, follow the instructions you have in the built html to enable the
>> i18n
>> > translation process.
>> > If you have any feedbacks, you can do it via a Github issue , a PR or in
>> > this thread.
>> > At the end, when everything will be Ok, I will make a new PR from my
>> branch,
>> > for the documentation on documentation process.
>> > Regards
>> > Thomas Gratier
>> > 2013/10/10 Jeff McKenna <jmckenna at gatewaygeomatics.com>
>> >> Ok thank you Thomas.
>> >> -jeff
>> >> On 2013-10-10 12:58 PM, Thomas Gratier wrote:
>> >> > Hi,
>> >> > Jeff, Yves, I will finish and push the docs about the new system this
>> >> > week.
>> >> > Thomas Gratier (author of the two mentioned PR)
>> >> > 2013/10/10 Yves Jacolin <yves.jacolin at camptocamp.com
>> >> > <mailto:yves.jacolin at camptocamp.com>>
>> >> >     Thanks Jeff!
>> >> >     Y.
>> >> >     <mailto:jmckenna at gatewaygeomatics.com>>:
>> >> >     > I want to test this before merging.  I will do so and get back
>> to
>> >> > you.
>> >> >     > -jeff
>> >> >     > On 2013-10-10 4:50 AM, Yves Jacolin wrote:
>> >> >     >> Hello,
>> >> >     >> There are 4 pull requests [1] whit 2 of them look important
>> to me
>> >> >     (I18n system
>> >> >     >> and i18n pot file) as it can help to improve the translation
>> >> > process.
>> >> >     >> QGIS is using such system successfully with transiflex app
>> which
>> >> >     helps to get
>> >> >     >> website and documentation translated really fast.
>> >> >     >> I do think that this 2 PR are worth to be merged into master
>> >> > branch.
>> >> >     >> I would like to get your opinion (Jeff :) ) on this, may be we
>> >> >     can run a short
>> >> >     >> vote after discussion. I know that there are some discussion
>> on
>> >> >     this on the
>> >> >     >> FOSS4G code sprint but may be a broader discussion could help.
>> >> >     >> Thanks, :)
>> >> >     >> Y.
>> >> >     >> [1] https://github.com/mapserver/docs/pulls
>> >> >     > _______________________________________________
>> >> >     > mapserver-dev mailing list
>> >> >     > mapserver-dev at lists.osgeo.org
>> >> > <mailto:mapserver-dev at lists.osgeo.org>
>> >> >     > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> >> >     Responsable Formation et Support
>> >> >     Camptocamp France SAS
>> >> >     Savoie Technolac, BP 352
>> >> >     73377 Le Bourget du Lac, Cedex
>> >> >     Tel (France) : +33 4 79 26 57 98<tel:%2B33%204%2079%2026%2057%2098>
>> >> >     Tel (Suisse) : 021 619 10 43
>> >> >     Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
>> >> >     Fax : 04 79 70 15 81
>> Mail : yves.jacolin at camptocamp.com
>> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20131028/ab839b6d/attachment.html>
