[mapserver-dev] New ScribeUI 0.3 Release
Umberto Nicoletti
umberto.nicoletti at gmail.com
Fri Sep 6 22:59:05 PDT 2013
Jessica, would you mind sharing some screenshots?
On Sep 6, 2013 10:31 PM, "Jessica Lapointe" <jlapointe at mapgears.com> wrote:
> Hi List,
> ScribeUI is a tool meant to help the editing and management of mapfiles,
> supporting Scribe and Standard mapfile syntax. I am currently developing
> this tool as a Google Summer of Code project.
> The Google Summer of Code ending very soon, the goal of this new release
> is bugfixes, and the beginning of the new plugin system! Please keep in
> mind that a lot of bugs remain, any feedback is welcome, should it be new
> feature ideas, general comments or bug reports.
> *What's new ?*
> - Fixed issue #11. This bug caused the client not to keep up with maps
> deleted in the backend.
> - Added the current zoom level on the map! ( issue #12 ) This makes it
> much easier to define your Scribe scale ranges.
> - Fixed font size issue #14, the browser tab is now much more
> comfortable to use.
> *Work In Progress*
> Still in progress is a simple plugin system. Some functions were added on
> the client side to make it easy to add buttons and tabs to the interface.
> The back-end side of plugins is not supported yet.
> *Download*
> ScribeUI and its installation instructions are available on github:
> https://github.com/mapgears/scribeui
> To get ScribeUI 0.3, you can clone the repo on github and checkout v0.3 or
> you can download an archive:
> https://github.com/mapgears/scribeui/releases/tag/v0.3*
> Bug reports can be made on github:
> https://github.com/mapgears/scribeui/issues
> Thanks a lot!
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130907/d3ebf75d/attachment.html>
