[mapserver-dev] New ScribeUI 0.3 Release
Jessica Lapointe
jlapointe at mapgears.com
Mon Sep 9 08:09:23 PDT 2013
Hi Humberto,
Since this is a tag you cannot clone the repository using the tag's url
directly. You should either download a zip at the tag's url:
https://github.com/mapgears/scribeui/releases/tag/v0.3
Or clone the main repo ( https://github.com/mapgears/scribeui ) and then
use:
git checkout tags/v0.3
Thank you!
Jessica
On Mon, Sep 9, 2013 at 10:24 AM, Humberto Cereser Ibanez <
humberto at pastoraldacrianca.org.br> wrote:
> Hi Jessica,
> > Hi List,
> > ScribeUI is a tool meant to help the editing and management of
> > mapfiles, supporting Scribe and Standard mapfile syntax. I am
> > currently developing this tool as a Google Summer of Code project.
> > The Google Summer of Code ending very soon, the goal of this new
> > release is bugfixes, and the beginning of the new plugin
> > system! Please keep in mind that a lot of bugs remain, any feedback is
> > welcome, should it be new feature ideas, general comments or bug
> > reports.
> > What's new ?
> > * Fixed issue #11. This bug caused the client not to keep up
> > with maps deleted in the backend.
> > * Added the current zoom level on the map! ( issue #12 ) This
> > makes it much easier to define your Scribe scale ranges.
> > * Fixed font size issue #14, the browser tab is now much more
> > comfortable to use.
> > Work In Progress
> > Still in progress is a simple plugin system. Some functions were added
> > on the client side to make it easy to add buttons and tabs to the
> > interface. The back-end side of plugins is not supported yet.
> > Download
> > ScribeUI and its installation instructions are available on
> > github: https://github.com/mapgears/scribeui
> > To get ScribeUI 0.3, you can clone the repo on github and checkout
> > v0.3 or you can download an archive:
> https://github.com/mapgears/scribeui/releases/tag/v0.3https://github.com/mapgears/scribeui/releases/tag/v0.3
> When I tried to clone the 0.3 version, I got the message:
> git clone https://github.com/mapgears/scribeui/releases/tag/v0.3
> Cloning into v0.3...
> warning: remote HEAD refers to nonexistent ref, unable to checkout.
> Has the default branch on the remote repository been deleted?
> > Bug reports can be made on github:
> > https://github.com/mapgears/scribeui/issues
> > Thanks a lot!
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Thanks,
> Humberto
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130909/b8a41d82/attachment.html>
