[mapserver-dev] MapCache changes to support MSVC and IIS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Aug 11 05:46:47 PDT 2014
Hi Tamas,
I have been using an older MapCache version for my recent MS4W builds,
so I'd be happy to test the MSVC changes in MapCache - you will be
applying these changes in master correct? (and also in branch-1-2
possibly?)
Talk soon,
-jeff
On 2014-08-10 6:53 PM, Tamas Szekeres wrote:
> Hi,
> I'm about to include MapCache to the regular builds of
> http://www.gisinternals.com/sdk/ and add MapCache to the provided
> MapServer Windows (msi) installer as well.
> This effort entails to apply a couple of fixes in MapCache to support
> building the code with MSVC and running the application in IIS server.
> I've submitted/updated the following issues which should be sorted out
> in order to achieve the expected result:
> MSVC10 compile failure <https://github.com/mapserver/mapcache/issues/75>
> CGI response is being truncated in IIS
> <https://github.com/mapserver/mapcache/issues/109>
> HTTPS is not correctly identified in CGI mapcache
> <https://github.com/mapserver/mapcache/issues/106>
> zlib is not added to the linker when png lib is used
> <https://github.com/mapserver/mapcache/issues/111>
> Add cmake check for timegm
> <https://github.com/mapserver/mapcache/issues/112>
> Missing dll exports in mapcache lib (MSVC)
> <https://github.com/mapserver/mapcache/issues/110>
> Support for default configuration location
> <https://github.com/mapserver/mapcache/issues/108>PATH_INFO is not
> correctly handled with IIS + CGI mapcache
> <https://github.com/mapserver/mapcache/issues/107>
> While I volunteer to fix these issues by myself, it would be great if
> someone could review the suggested solutions. Even more so because I
> want to apply these changes to the stable branch too.
> Best regards,
> Tamas
