[mapserver-dev] Multiline string error
Ian Walberg
ian.walberg at airborne.aero
Wed Aug 13 19:38:10 PDT 2014
Steve,
Version 6.4.1 built on the same machine with the same settings does not have the issue.
Regards
Ian
-----Original Message-----
Sent: Wednesday, August 13, 2014 3:43 PM
To: 'Lime, Steve D (MNIT)'; 'mapserver-users at lists.osgeo.org'; 'mapserver-dev at lists.osgeo.org'
Subject: RE: Multiline string error
Steve,
We will add some debug to the OGR read later today or tomorrow.
How do I turn on the maximum debug?
Thanks
Ian
Sent: Wednesday, August 13, 2014 3:20 PM
To: 'Lime, Steve D (MNIT)'; mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Steve,
OGR connection to SQLITE DB.
Regards
Ian
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: Wednesday, August 13, 2014 8:46 AM
To: Ian Walberg; mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
How are you submitting the WKT to MapServer? Is it via MapScript, via inline features or some other mechanism?
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Wednesday, August 13, 2014 10:01 AM
To: mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Multiline string error
Devs,
The MULTILINE string below gives the following in mapprimitive.c and then as the first shape has 0 points the msSmallMalloc fails as the size passed to it is -8.
[Wed Aug 13 07:55:10 2014].618971 Shape contains 2 parts.
[Wed Aug 13 07:55:10 2014].618987 Part 0 contains 0 points.
[Wed Aug 13 07:55:10 2014].619001 Part 1 contains 3 points.
[Wed Aug 13 07:55:10 2014].619016 0: (882.383078, 511.333078)
[Wed Aug 13 07:55:10 2014].619032 1: (825.909890, 260.048026)
[Wed Aug 13 07:55:10 2014].619049 2: (882.383078, 511.333078)
Any clues what we should look at next?
This same source data file and layer work with older versions of mapserver 6.
Thanks
Ian
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Monday, August 11, 2014 3:53 PM
Subject: [mapserver-users] Multiline string error
Folks,
With Mapserver 6.5-dev from git and GDAL 1.9.1 the line below either does not draw or causes mapserv to error and not render an image without an error message.
MULTILINESTRING ((-110.220980 38.982832, -110.220887 38.982863, -110.221614 38.982708, -110.220980 38.982832),(-110.220980 38.982832, -110.220887 38.982863, -110.221614 38.982708, -110.220980 38.982832))
Changing the final digit on either of the first or last lats/longs and it draws ok!
Any ideas?
Thanks
Ian
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
