[mapserver-dev] Multiline string error
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Thu Aug 14 07:40:21 PDT 2014
One quick thing to do would be to take OGR out of the mix. Just set up a mapfile with the feature in question as a WKT inline feature. Something like:
LAYER
NAME 'badwkt'
TYPE LINE
STATUS DEFAULT
FEATURE
WKT ' MULTILINESTRING ((-110.220980 38.982832, -110.220887 38.982863, -110.221614 38.982708, -110.220980 38.982832),(-110.220980 38.982832, -110.220887 38.982863, -110.221614 38.982708, -110.220980 38.982832))'
END
CLASS
STYLE COLOR 0 0 0 END
END
END
Then try to draw... If this fails then it's a MapServer issue.
Steve
-----Original Message-----
From: Ian Walberg [mailto:ian.walberg at airborne.aero]
Sent: Wednesday, August 13, 2014 9:38 PM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Subject: RE: Multiline string error
Steve,
Version 6.4.1 built on the same machine with the same settings does not have the issue.
Regards
Ian
Sent: Wednesday, August 13, 2014 3:43 PM
To: 'Lime, Steve D (MNIT)'; 'mapserver-users at lists.osgeo.org'; 'mapserver-dev at lists.osgeo.org'
Steve,
We will add some debug to the OGR read later today or tomorrow.
How do I turn on the maximum debug?
Thanks
Ian
Sent: Wednesday, August 13, 2014 3:20 PM
To: 'Lime, Steve D (MNIT)'; mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Steve,
OGR connection to SQLITE DB.
Regards
Ian
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: Wednesday, August 13, 2014 8:46 AM
To: Ian Walberg; mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
How are you submitting the WKT to MapServer? Is it via MapScript, via inline features or some other mechanism?
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Wednesday, August 13, 2014 10:01 AM
To: mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Multiline string error
Devs,
The MULTILINE string below gives the following in mapprimitive.c and then as the first shape has 0 points the msSmallMalloc fails as the size passed to it is -8.
[Wed Aug 13 07:55:10 2014].618971 Shape contains 2 parts.
[Wed Aug 13 07:55:10 2014].618987 Part 0 contains 0 points.
[Wed Aug 13 07:55:10 2014].619001 Part 1 contains 3 points.
[Wed Aug 13 07:55:10 2014].619016 0: (882.383078, 511.333078)
[Wed Aug 13 07:55:10 2014].619032 1: (825.909890, 260.048026)
[Wed Aug 13 07:55:10 2014].619049 2: (882.383078, 511.333078)
Any clues what we should look at next?
This same source data file and layer work with older versions of mapserver 6.
Thanks
Ian
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Monday, August 11, 2014 3:53 PM
Subject: [mapserver-users] Multiline string error
Folks,
With Mapserver 6.5-dev from git and GDAL 1.9.1 the line below either does not draw or causes mapserv to error and not render an image without an error message.
Changing the final digit on either of the first or last lats/longs and it draws ok!
Any ideas?
Thanks
Ian
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
