[mapserver-dev] FW: [mapserver-users] WMS request fails when spaces are encoded as plus symbol in query part of URL
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Wed Aug 20 23:57:49 PDT 2014
Here is an ArcGIS WMS to test with.
http://gtkdata.gtk.fi/arcgis/services/GTKWMS/GTKWMS/MapServer/WMSServer?request=GetCapabilities&service=WMS
Do it quickly because I have asked the service provider to change the layer names, and guess what - because I could not make our Mapserver to cascade the service. You will find layer names like
<Name>Maaperä 1:20 000; 1:50 000</Name>
I would really much like to know also how the non-ascii characters should be handled in the mapfile when cascading such layers.
-Jukka Rahkonen-
> I agree it's a change that should slip in now for 7.0, but I hope those with later
> ArcServer versions can test it in the beta (or we have one volunteer to let us use
> their Arc WMS instance for testing).
> -jeff
> On 2014-08-20 1:52 PM, Lime, Steve D (MNIT) wrote:
> > Devs: Is this a change that we should make for 7.0? Seems reasonable
> > but I'm not sure what the side effects might be.
> > Steve
> > *From:*Moen, Paul T. [mailto:pmoen at nd.gov]
> > *Sent:* Wednesday, August 20, 2014 9:44 AM
> > *To:* Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
> > *Subject:* Re: [mapserver-users] WMS request fails when spaces are
> > Steve,
> > You are right about the outcome of 1 and 2. 1 encodes the % and 2
> > throws the following error.
> > msBuildWMSLayerURLBase(): One of wms_onlineresource,
> > wms_server_version, wms_name metadata is missing in layer USGS DRG
> > 250k Topo Maps. Please either provide a valid CONNECTION URL, or
> > provide those values in the layer's metadata.\n\n
> > I found the function as you said and
> > I removed the
> > if (*i == ' ')
> > *j = '+';
> > else
> > from the function then recompiled.
> > char *msEncodeUrlExcept(const char *data, const char except)
> > char *hex = "0123456789ABCDEF";
> > const char *i;
> > char *j, *code;
> > int inc;
> > unsigned char ch;
> > for (inc=0, i=data; *i!='\0'; i++)
> > if (msEncodeChar(*i))
> > inc += 2;
> > code = (char*)msSmallMalloc(strlen(data)+inc+1);
> > for (j=code, i=data; *i!='\0'; i++, j++) {
> > if ( except != '\0' && *i == except ) {
> > *j = except;
> > } else if (msEncodeChar(*i)) {
> > ch = *i;
> > *j++ = '%';
> > *j++ = hex[ch/16];
> > *j = hex[ch%16];
> > } else
> > *j = *i;
> > *j = '\0';
> > return code;
> > Everything works again after a mapserver recompile, install and
> > finally a restart of apache. Thanks so much for the path to the solution.
> > Paul Moen
> > pmoen at nd.gov <mailto:pmoen at nd.gov>
> > 701-328-2434
> > *From: *<Lime>, "Steve D (MNIT)" <Steve.Lime at state.mn.us
> > <mailto:Steve.Lime at state.mn.us>>
> > *Date: *Wednesday, August 20, 2014 at 12:41 AM
> > *To: *Paul Moen <pmoen at nd.gov <mailto:pmoen at nd.gov>>,
> > "mapserver-users at lists.osgeo.org
> > <mailto:mapserver-users at lists.osgeo.org>"
> > <mapserver-users at lists.osgeo.org
> > <mailto:mapserver-users at lists.osgeo.org>>
> > *Subject: *RE: [mapserver-users] WMS request fails when spaces are
> > Hmmm... Nice backwards compatibility ESRI. The +'s seem to still be
> > quite legal (http://tools.ietf.org/html/rfc3986 and other references)
> > in the query string (but not the path). I don't have access to test
> > and I'm guessing these ideas won't work but they might be worth a quick try:
> > 1) Try encoding the wms_name in the metadata: "wms_name"
> > "Topomap%20DRG%20250k"
> > 2) Don't set the wms_name in the metadata but add it to the
> > connection: CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?L
> AYERS=Topomap%20DRG%20250k&"
> > I'm betting MapServer will encode the %'s in 1 and throw an error in 2.
> > Otherwise you could hack the MapServer source. Function is called
> > msEncodeUrlExcept() in mapstring.c you can see the section to change
> > starting at line 1138 in git master
> > (https://github.com/mapserver/mapserver/blob/master/mapstring.c)
> > <https://github.com/mapserver/mapserver/blob/master/mapstring.c).>
> > Maybe it's worth making this change as part of 7.0?
> > Steve
> > *From:*mapserver-users-bounces at lists.osgeo.org
> > <mailto:mapserver-users-bounces at lists.osgeo.org>
> > [mapserver-users-bounces at lists.osgeo.org
> > <mailto:mapserver-users-bounces at lists.osgeo.org>] on behalf of Moen,
> > Paul T. [pmoen at nd.gov <mailto:pmoen at nd.gov>]
> > *Sent:* Tuesday, August 19, 2014 4:56 PM
> > *To:* mapserver-users at lists.osgeo.org
> > *Subject:* [mapserver-users] WMS request fails when spaces are encoded
> > Hi all,
> > We are consuming WMS services hosted by ESRI ArcGIS Server 10.0. The
> > server was upgraded to ArcGIS Server 10.2.2 and we no longer can
> > access layer names with spaces.
> > This is the server's capabilities.
> > This is the layer I am using.
> > LAYER
> > # DEBUG 5
> > CONNECTIONTYPE WMS
> > CONNECTION
> "http://ndgishub.nd.gov/arcgis/services/All_Elevation/MapServer/WMSServer?"
> > METADATA
> > "wms_name" "Topomap DRG 250k"
> > "wms_format" "image/png"
> > "wms_server_version" "1.1.1"
> > "wms_srs" "EPSG:2266"
> > END
> > TYPE RASTER
> > STATUS OFF
> > NAME "USGS DRG 250k Topo Maps"
> > END
> > Mapserver encodes this request as follows. Notice that the layer
> > name, which is 'Topomap DRG 250k', is encoded with the spaces becoming the
> > character.
> er?LAYERS=Topomap+DRG+250k&REQUEST=map&WMTVER=1.0.0&SERVICE=W
> MS&FORMAT
> =image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BBOX=19
> 06240.1
> 5992838,596656.333359479,2119730.85012732,789150.692893686&TRANSPAR
> ENT
> > =TRUE&EXCEPTIONS=INIMAGE
> > This returns the error in an image that says "Parameter 'layers'
> > contains unacceptable layer names."
> > When I replace the + in the layer name with %20,
> > LAYERS=Topomap+DRG+250k become LAYERS=Topomap%20DRG%20250k
> and the request becomes the following.
> er?LAYERS=Topomap%20DRG%20250k&REQUEST=map&WMTVER=1.0.0&SERVI
> CE=WMS&FO
> RMAT=image/png&STYLES=&HEIGHT=1146&SRS=EPSG:2266&WIDTH=1271&BB
> OX=19062
> 40.15992838,596656.333359479,2119730.85012732,789150.692893686&TRAN
> SPA
> > RENT=TRUE&EXCEPTIONS=INIMAGE
> > That request works. Obviously, ESRI is no longer decoding + as a
> > space and therefore does not recognize the layer name with spaces.
> > Is there any way I can have mapserver encode all characters using
> > percent-encoding, or at least encode spaces as %20 instead of a + character.
> > Thanks,
> > Paul Moen
> > 701-328-2434
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
