[mapserver-dev] Regarding to the issue: segfault on transparent layers with new renderers (#3834)
Tamas Szekeres szekerest at gmail.com
Sun Aug 24 09:27:19 PDT 2014
No comments so far.
I've prepared a fix to show what I've meant by storing the outputformat
instead of the renderer vtable in symbolObj.
https://github.com/szekerest/mapserver/commit/f4a4a2831a3d6228181938c0761fa5caf06c6452
Let me know if such change can be applied in master.
This change also contains a fix for the memory leaks caused by the embedded
scalebar and legend symbols which is necessary for making the refcount
approach to work properly.
We might also utilize MS_REFCNT macros for the outputformat refcount
handling too (which are not yet used), but that would involve further
changes to be made in further files.
Best regards,
Tamas
2014-08-20 17:42 GMT+02:00 Tamas Szekeres <szekerest at gmail.com>:
> Hi Devs,
> Regarding to #3834 <https://github.com/mapserver/mapserver/issues/3834>,
> I can see several hacks in the code attempting to fix the issue, but it
> seems we are still running into the same issue by getting a crash in
> msFreeSymbol at the line:
> s->renderer->freeSymbol(s);
> We've already been discussing about implementing a symbol cache at the
> renderers (and eliminate the need of maintaining back references to the
> renderer at symbolObj), however that seems to require fair amount of coding
> and testing at the first sight.
> What if we change the renderer reference in symbolObj from
> rendererVTableObj to outputFormatObj (which contains the vtable)? Since the
> outputformat is reference counted we could make sure the outputformat (and
> the vtable) exists until the corresponding symbolObj is alive?
> Best regards,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140824/0fc06e23/attachment.html>
