[mapserver-dev] c unit tests in MapServer
geographika
geographika at gmail.com
Wed Dec 3 06:55:59 PST 2014
Hi list,
With almost 20 years of development, the MapServer codebase can be
overwhelming at first. For most open source projects I've found the
easiest way into helping with a project is:
1. Reporting bugs
2. Finding the problematic code
3. Submitting a patch and unit test.
In 2006 there was a Request For Comments (#12) by Umberto Nicoletti
about adding C Unit tests:
http://www.mapserver.org/development/rfc/ms-rfc-12.html
Also see GitHub issue #1664:
https://github.com/mapserver/mapserver/issues/1664
Obviously a full test suite of existing code isn't possible, however if
the testing framework and skeleton folder/file structure was set up it
may help more concrete contributions from developers outside of the core
MapServer team.
There have been a few bugs I've submitted where I would feel comfortable
adding a unit test to an existing file to show the error, but creating
full msautotest examples seems very daunting. As a concrete example
while testing the latest dev build I noticed the msParseTime function in
the maptime.c module threw an error. Unit tests for this function seem
like the perfect solution for these types of bugs, and to avoid breaking
changes in the future.
https://github.com/mapserver/mapserver/commit/0cc47e3027a75cf18c5310694877999c6b245371
C Unit tests have come up a few times in the past e.g. Paul Ramsey's
post about PostGIS driver testing:
http://osgeo-org.1560.x6.nabble.com/cunit-RFC-12-td4261340.html
Frank Warmerdam's response (in 2008) was -
My preference remains to test specific functions as part of a larger
operations since we already have such technology in place (ie. msautotest)
or to expose the functionality through mapscript and use mapscript tests
like Sean's python unit tests.
I do not feel that introducing another testing methodology into the
project would be wise.
The Python unit tests are again useful, but require testing against full
builds, a difficult task for those not familiar with make files and
gathering dependencies.
Testing database drivers as I understand it would require a full test
database setup with msautotest, whereas for many bugs it is clear which
function needs modifying and a unit test could be added quickly to
highlight and help fix the bug.
I've only experience in Python and .NET unit testing so perhaps C
testing is more trouble than it is worth.
I guess it is up to the core devs whether it has any benefit to
themselves, or the project as a whole, whether this issue should be
reconsidered.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20141203/ccfa82d5/attachment.html>
